OK, so i'm planning on buying a graphics card but it can be complicated. The more i read and watch about it, more i'm confused. At first i thought just, bigger numbers are better but then i came upon this:
2 cards with similar price tag (around 135€
with pretty different specs but similar benchmark. Feature set is also different so i would need a help from you guys.
I like the idea of having crossfire option there for future upgrade (is this even a good idea, or should i just replace my GPU after a while instead of buying CF duplicate), plus i saw 260x is the lowest (cheapest) model from ATI that support Freesync and dynamic refresh rate: All AMD Radeon™ graphics cards in the AMD Radeon™ HD 7000, HD 8000, R7 or R9 Series will support AMD FreeSync™ technology for video playback and power-saving purposes. The AMD Radeon™ R9 295X2, 290X, R9 290, R9 285, R7 260X and R7 260 GPUs additionally feature updated display controllers that will support dynamic refresh rates during gaming. LINK: http://support.amd.com/en-us/search/faq/219
I do not have a freesync monitor, it's just i'm trying to set up a future proof rig.
1. VGA Sapphire R7 260X OC 1 GB DDR5
2. VGA Asus R7 260X OC 2 GB DDR5
How come 1GB version supports display res: 4096x2160, while 2GB only 2560x1600? Sapphire also features much longer feature list. I have no idea how much that affects my experience, but shouldn't that feature list be exact same as the GPU is exactly the same?
And benchmarking:
Benchmarking doesn't seem to make any big difference as well...
Which one would you get?
I'm sorry for such a long post,
Ryan
And benchmarking:
Ryan
