Sugeknight
1. What YOUR PC will be used for.
some gaming, multimedia, development, file transers, file conversions
2. What YOUR budget is.
$1800-2100
3. What country YOU will be buying YOUR parts from.
US, Newegg
4. IF YOU have a brand preference.
prefer Intel
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
all new parts
6. IF YOU have searched and/or read similar threads.
I've searched build threads and have a few related questions below. I haven't built a machine in 3 years so I've been researching as much as possible.
7. IF YOU plan on overclocking or run the system at default speeds.
no plans to overclock
8. What resolution YOU plan on gaming with.
1080
9. WHEN do you plan to build it?
as soon as the part choices are finalized
Questions:
The Sapphire video card is out of stock, any suggestions to sub?
Would i7 be worth the performance bump?
Any reasons why SSD is a bad idea?
Thoughts on where price can be trimmed?
Comments/suggestions?
This is my current build:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=11896711
Thanks!
updated
-COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case
-CORSAIR CMPSU-650TX 650W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply
-GIGABYTE GA-P55A-UD3 LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
-Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor BX80605I5750
-COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long ...
-qty 2 - G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
-XFX HD-585X-ZAFC Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
-Intel X25-M Mainstream SSDSA2MH080G2R5 2.5" 80GB SATA II MLC Internal Solid State Drive (SSD)
-HITACHI Deskstar HD32000 IDK/7K (0S00164) 2TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
-ASUS VE246H Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor
-LITE-ON 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support
-Logitech G500 10 Buttons Dual-mode Scroll Wheel USB Wired Laser Gaming Mouse
-Logitech 967740-0403 Black USB Standard Internet 350 USB Keyboard - OEM
-Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM
$1800-2100
US, Newegg
prefer Intel
all new parts
1080
Questions:
Thanks!
updated
