- Jan 3, 2006
- 11,883
- 63
- 91
Cheap build for a HTPC setup. Will be in a cheap case to start with (since I have one lying around). Will shop for a better HTPC style case as time goes on.1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Focusing on processing power due to HD content. (Blu-ray drive, Divx HD, any of the other popular codecs).
Hooked up to an HDTV via HDMI, and a cheap Pioneer 5.1 system via digital optical. TV's VGA port will not support HD (VGA res only), so a card with HDMI out or DVI-HDMI converter needed.
I'm easy. I'll stay away from silly things like extreme edition processors or quad core setups. Build date will be a long ways from now. I know the dangers of buying a part at a time, but this will have to do. For example. I can drop a couple hundred bucks on a cpu/mobo combo, then select RAM, P/S, etc. in the following weeks. I'll do my best with this breakdown.2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread.
Mobo/CPU: 200-250
Video Card: 150ish
P/S: With all the deals going around 80+ certified.... sub 100? Earthwatts?
Sound: OEM CL x-fi? I heard they suck at Vista. What about an ATI card (HD 3850) that HW decodes Blu-Ray and it's audio? I have one on my desktop, can I buy something similar to knock out two birds with one stone?
Media Center-tric keyboard, remote: 100-130. Will a Logitech Harmony integrate well? I have a 550 for my current HT setup.
N Wireless card: 100 bucks?
HD: Nothing fancy, I intend to stream HiDef from my Buffalo NAS via N wireless if I can. Yes, I am gutsy. If that doesn't work out, I'll wire it up with CAT 5, or get a bigger HD.
OS: Vista Home Premium or Ultimate due to Media Center. 170 or less.
Blu-ray drive: 150? Don't need to burn BR's for now.
The US of A.3. What country YOU will be buying YOUR parts from.
Virtually no preference. I had AMD rigs in the past, but my Intel 8400 is serving me well on my desktop. I have Seagate drives up the wazoo, but I am flexible.4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Case. It's a budget Cooler Master that can take a ATX mobo.5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Remote. Logitech Harmony 550? Will it work?
I would lie if I said I researched this6. IF YOU have searched and/or read similar threads.
No. Would like to run a stock cooler, and not mess with endless stress test. My 8400 with stock cooler is really quiet.7. IF YOU plan on overclocking or run the system at default speeds.
First order for parts in a couple of weeks. Completion could take the rest of the summer.8. WHEN do you plan to build it?
Cliffs:
HTPC from a non HTPC case. Not planning on watching TV with it. Just Blu-ray movies, and streaming HD from the NAS via N wireless. Also, plan on making ISO's or converting my current DVD collection to Divx (conversion will be done with my desktop). HD DVR from the cable company will meet my TV needs for now.
Would like to know about how to properly HW decode the Blu-ray video, and DTS and Dolby Digital audio formats.
Update: Bought everything. Doesn't work.
Gigabyte board, 78G
AMD 64 X2 4200, AM2
Maxtor 500GB SATA
OCZ 2GB 6400
LG BR/HD-DVD combo drive.
Antec Basiq 500W. Cheap, feels really light.
-----------Update 1------------------------------6-26----------------------------
It doesn't power on at all. Reseated everything, pins look straight and true. I had to turn down the TV, but the P/S make a slight sound when tryinig to turn on. Kind of like a camera flash powering on, but in reverse and very, very faint. I think a cap is bad.
Going to return it tonight for an Earthwatt 380 or 430.
----------Update 2------------------------------6-26---------------------------
Returned the P/S. Thank God the Fry's rep put "return to vendor" on it. Got a Earthwatts 380. Plugged it in, and got success!
Windows XP blue screened if I enabled AHCI, so I am leaving it off. Hoping that's what it was.
Now for HDMI questions? What's the best way to set this up. I know I have to select the digital output in the BIOS, but for Windows Display settings, do I just put in the res for 720p and 60hz? Is that safe for a standard Westinghouse LCD HDTV?
For what's it's worth I tried the BR player using the Pixar/Disney Cars movie on my desktop last night. Holy Crap!!!!! I was only 1.5 feet away from my monitor, and it's downright dreamy in 1080p. Too bad my Westy is only 720p.
btw-everyone's input is very valuable. Thanks!
