First, I have read most of the posts dealing with flickering monitors.
I have a workstation that is causing this problem. The monitor is flickering, both in the startup screens and in NT4. When set to 60 hz, all you see is the flickering from the low refresh rate. In bootup and when I change to a higher refresh rate, the monitor begins "shaking" the image.
I have done the following: Changed monitors, changed video cards, changed the pci slot for the video card, moved the monitor from the beginning location, moved the computer to another room, changed power supplies, changed power wires on both the monitor and tower, changed electrical outlets. The monitor I am using now is an NEC FV700. The monitor before was an Acer. The both support high refresh rates.
The key, I believe, is the fact that it does this shaking in bootup, including the bios setup screen. The only other thing I was thinking it could be, would be the motherboard. I am open to any and all suggestions.
