Help with first mod
Jake6
I just ordered a Global win YCC-61F1 case yesterday. It has a 120mm fan in front of the hard drive cage and a 120mm exhaust fan. This case has the dimensions of 460 X 240 X 560 mm. I am considering doing my first mod. THinking of putting a 92mm fan in the top and a 120 mm fan on the side cover blowing on the video card. I had ordered a Enermax adjustable fan on both of these. THinking on low speed they work ok. I am just looking for suggestions from some of you much more experienced than I. Still contemplating whether it would be beneficial.
Thanks in advance
OK any reason why you would want to change something without knowing if anything needs changing ?
See how the case performs first with the stock fans in place (if it comes with any) and if you think it requires more cooling then make the mods to it.
I would think that those fans would be adequate for what you need though.
I found a good review of this case here http://www.overclockercafe.com
