- Apr 15, 2005
- 4,108
- 29
- 91
My setup:
X58 Supercomputer
i7 920
6gb (3x2gb) DDR3 1600
Antec 550
My goal (I know I could go higher, but I don't really want to) is 3.6ghz. So far, I have these settings getting me to 3.6ghz Prime95 stable:
BCLK: 180
Spread Spec: Auto
QPI: 6.48
Uncore: 3240
DRAM Freq: 720mhz DDR 1440
Vcore: 1.35000 (1.248 reported by CPU-Z when Prime95ing, and why the difference is voltage in the BIOS vs CPU-Z, vdroop? Does this seem like a high voltage to anyone?)
DRAM: 1.647
VTT Offsest: +300mV
CPU PLL: 1.86
Everything else in the BIOS has been left at Auto, including Multiplier. Is there anything else I should look at changing or modifying (voltages, multipliers, etc) that are currently set to Auto that would be better off set manually?
Edit: Are these core temps normal?
Core 0: 82°C
Core 1: 81°C
Core 2: 77°C
Core 3: 75°C
Is that much variance between cores normal, or would it be worth it to try rotating my HSF 90°?
BTW: My HSF is the Sunbeamtech 120 Core-Contact Freezer with the 1366 adapter (this was originally a 775 cooler)
http://www.sunbeamtech.com/PRODUCTS/cooler/Core-ContactFreezer.html
X58 Supercomputer
i7 920
Antec 550
BCLK: 180
Spread Spec: Auto
QPI: 6.48
Uncore: 3240
DRAM: 1.647
VTT Offsest: +300mV
CPU PLL: 1.86
Core 0: 82°C
Core 1: 81°C
Core 2: 77°C
Core 3: 75°C
