Help with finishing my build!
Discussion in 'General Hardware' started by zantaff, Jan 6, 2013.
  1. zantaff
    zantaff Member
    Jan 5, 2013
    28
    Hello!
    I'm about done with all the big decisions on my new build and am looking for a GPU and some other parts.
    I kinda splurged online when buying my first parts.
    The original intent was to do a sub-$600 machine, and I've already spent $400... So now I'm kinda strapped for cash.
    What I just bought:
    i5 3570K ($190)
    ASUS P8Z77-V PRO ($145)
    Rosewill HIve 650w ($66)
    What I'm going to reuse from my old PC:
    HDDs
    CD/DVD
    2 1gb of RAM
    Front interface ports
    This will mainly be a gaming computer, but will be also used for some graphic design & 3-D modeling.
    Because my original plan seems unrealistic... I'm dropping it. Now I'm just looking for good parts to finish my build.
    They don't need to be THE BEST, just quality parts. Perhaps there are some deals out there?
    I am willing to sacrifice in places right now where it is easy to upgrade later.
    Keep in mind I still have to buy:
    a CASE
    Fans
    8+gb RAM
    1 SDD (boot)
    Other things? (Am I being dumb?)
    So, where should I go from there? Should I buy used or new?
    Any suggestions are appreciated.
    Thanks!
    #1 zantaff, Jan 6, 2013
  2. Loading...
    Similar Threads - finishing build Forum Date
    Finally 'finished' Nini-ITX build... General Hardware Oct 29, 2016
    Got parts, need case, cpu fan, maybe new psu to finish micro atx build General Hardware Feb 8, 2016
    Just finished building my new rig. What is the order of installing drivers after OS? General Hardware Oct 31, 2014
    Thanks for the build advice. Update: Finished! General Hardware Feb 21, 2014
    help finishing off my build General Hardware Aug 20, 2013
  3. runzwithsizorz
    runzwithsizorz Diamond Member
    Jan 24, 2002
    3,452
    9
    Ram? Others may have a different opinion, but I honestly don't see how you can build this with what you have already bought for less than 1,000.00. Your ideas are good, but a decent vid card alone will go for 170.00 or more.
  4. zantaff
    zantaff Member
    Jan 5, 2013
    28
    Sorry, i derped the first time I typed it. Fixed it now.
    I suppose my real question is: what could do without (or less of) until I get a few extra $$$ in my pocket?
    What parts should I buy first while saving my cash for the nicer equipment?
  5. JJ24
    JJ24 Member
    Jul 27, 2007
    70
    If I read your post correctly you have about $200 to get the following:
    Case
    GPU
    RAM
    SSD
    (Maybe extra case fans)
    Commonly recommended RAM:
    Ram is easy - Samsung DDR3 1600 = $40 for 2x4gb
    http://www.amazon.com/s/ref=nb_sb_ss...r3%2Caps%2C428
    Commonly recommended cases:
    Corsair Carbide 300R (200R is currently out of stock on Newegg but might find somewhere else...)
    $79.99 - http://www.newegg.com/Product/Produc...82E16811139011
    or maybe CM HAF 912 - $59.99 after rebate
    http://www.newegg.com/Product/Produc...&Tpk=haf%20912
    There are of course many other random brand cases for less, but these two seem to be regularly recommended.
    We're already at $100-$110 leaving only $90ish for a GPU and SSD... At this point I'd drop the SSD and just go over your budget a bit for the GPU...
    Sapphire Radeon HD 7850 - 164.99 After Rebate
    http://www.newegg.com/Product/Produc...82E16814202004
    That puts you at your original $400+40+60(Cheaper case)+165 = $665 without an SSD
    Maybe someone else can come along and make some better recommendations or squeeze the SSD in somehow...
  6. zantaff
    zantaff Member
    Jan 5, 2013
    28
    Thanks! That was really thorough.
    I'd like to get am SSD to boot because I always seem to f-up my boot HDD... but like you said, it's one of the non-essentials in the build right now.
  7. runzwithsizorz
    Jan 24, 2002
    3,452
    9
    You will need at least 4 gig ram, ideally 8 gig...should be matched. However, ram is cheap. The problem is the rest. You've already spent 400.00, and what you have bought is fine, but I repeat: with 200.00 left, that will buy a vid card. Your main components and where you want to spend the money are CPU(you have bought a good one) and video card. Also, you will also need a good CPU cooler if you plan on overclocking. As I said, I honestly don't know how you can buy all these components with 200.00. Maybe someone else will have a solution, at least for part of your build.
    Sorry I couldn't be of more help.
  8. lehtv
    lehtv Lifer
    Dec 8, 2010
    11,655
    8
    You shouldn't have bought the P8Z77-V PRO. Even at $145 which is a great price for that board it's too expensive for your budget.
    The 650W PSU is also overkill. For a single GPU system requiring one 6-pin PCIe connector, you only need a 400W+ unit. For two connectors, 500W+.
    CPU+Mobo i5-3570K + Asrock Z77 Pro3 $297
    RAM 2x4GB Samsung DDR3 $40 (no point using your 2x1gb)
    GPU Sapphire 7850 1GB $170 AR
    SSD Plextor M5S 64GB $35 after gift card from 3570K
    HDD Reuse $0
    DVD Reuse $0
    Case Corsair 300R $50 AR AP (you don't need additional fans)
    PSU Corsair CX430 $20 AR AP
    = $612 AR AP
    This is what I'd recommend if it's possible for you to return what you've bought so far. If it's not, then I guess you'll have to splurge $700 to get both an SSD and a 7850, otherwise be prepared to forget about the SSD for now or settle for a 7770.
  9. zantaff
    zantaff Member
    Jan 5, 2013
    28
    I really liked the P8Z77. I was also looking at the Asrock Z77 at the same time, but couldn't pass up the P8 for $145.
    Also, with the PSU, I really wanted a modular system, so I splurged a bit there too.
    I'm definitely gonna go up to $700. - My fault for spending the extra money beforehand, but I think it'll be worth it.
  10. lehtv
    lehtv Lifer
    Dec 8, 2010
    11,655
    8
    But you don't need 650W. A 400-500W unit would have fewer connectors so there'd be fewer cables unused anyway
  11. DSF
    DSF Diamond Member
    Oct 6, 2007
    4,902
    There's not a problem with what you want. The problem is that $600 is not a "get what I want budget" it's a "get what I need" budget.
    Your "wants" are coming at too high of a price tag without adding performance, and they're getting in the way of needs that will make this a serviceable gaming rig. I agree with lehtv. If it's at all possible, return your motherboard and PSU for less expensive models. Even if you go up to $700 you're leaving performance on the table without doing that.
  12. Termie
    Termie Diamond Member
    Aug 17, 2005
    7,858
    40
    Drop the idea of extra case fans, buy the Samsung ram linked above and throw out the 2GB you have (it's worth like $5 and will probably screw up your build if you try to pair it with other sticks), and build the system without a gpu for now, running off the hd4000 until you have a bit more cash.
    Trying to buy a case, SSD, memory and graphics card now, even with your increased budget of $300, is just going to lead to an unbalanced system and major disappointment.
    And sorry, but the motherboard was still $50 too high for your budget, no matter how good the deal was. So save up more to make up for that slight misstep. You basically need another $50 in your budget for a proper gpu (the 7850, or if you aren't doing a lot of gaming, the 650ti).
    #11 Termie, Jan 6, 2013
  13. JJ24
    JJ24 Member
    Jul 27, 2007
    70
    I understand the feeling of really liking something so sticking with it even if its more then you technically need (right now) if you're able to keep what you have and expand your budget enough to squeeze in the SSD lehtv recommended (EPIC price right now btw) and the Sapphire 7850 you could always keep the option open to add another 7850 later in crossfire with that 650w PSU and the P8Z77.
    If you are not able to squeeze it all in right now I'd say drop the SSD but keep the 7850. You could add the SSD later if you wanted it and not miss out on the much better performance of the GPU right now.
  14. Termie
    Aug 17, 2005
    7,858
    40
    The plextor is already out of stock (not surprisingly), but honestly, I don't recommend he build without an SSD and then add it later. Way too much hassle to reinstall the OS.
    I'd get this - http://www.newegg.com/Product/Produc...82E16820147188.
    #13 Termie, Jan 6, 2013
  15. RaistlinZ
    RaistlinZ Diamond Member
    Oct 15, 2001
    7,617
    I agree with everything here. Spending $145.00 on a motherboard when your entire system budget is $600.00 is just silly. Save $50.00 off the mobo and put it towards a SSD boot drive. Save up more for a 7850 later on.
    When you're on a super tight budget you need to maximize performance per dollar spent. And you sould also try to eliminate bottlenecks if you can. 3570k(oc) + 7850(oc) + SSD will give you a nice balanced system.
  16. zantaff
    zantaff Member
    Jan 5, 2013
    28
  17. lehtv
    lehtv Lifer
    Dec 8, 2010
    11,655
    8
    Buying used is fine when the item has most of its warranty left, and the savings compared to a new comparable item are substantial
  18. zantaff
    zantaff Member
    Jan 5, 2013
    28
    Changed first post, because I realized my goals were unrealistic.
  19. DSF
    DSF Diamond Member
    Oct 6, 2007
    4,902
    I take it you don't consider returning things an option? You really could more effectively allocate the money you've already spent.
  20. mfenn
    mfenn Elite Member <br> Currently on <BR> Moderator Sabb
    Jan 17, 2010
    22,403
    I don't see a budget in the first post? Other than the original $600 one.
  21. Termie
    Aug 17, 2005
    7,858
    40
    Are you saying that you're skipping the gpu for now?
    If so, just get the Samsung SSD for $100, the Samsung memory for $40, the Corsair case for $50, and hold on to the remaining $100 until you have enough for a $160 gpu.
  22. zantaff
    zantaff Member
    Jan 5, 2013
    28
    Not necessarily. However, I do have an old xfx radeon 4550 that I can use to get by until my next paycheck.
    Also, the graphical programs I use are: Adobe Suite, AutoCAD, Revit & 3DS Max.
    I could, but since I ordered things online, I don't think the shipping costs would make it worth wile.
    One upside of the Asus Pro is that it has a good built-in WiFi, so I don't need to spend another $60+ on a reciever.
    (Literally no ethernet sockets in my apartment.)
    I figured that way, it balances out the difference in the Asrock, and I get a better performing board as well.
    That's right. Since $600 was so unrealistic, I dropped the budget so I wasn't constrained by it anymore.
    I'd like to see what people will come up with, and then decide what to get based on that.
    I /guess/ the budget could be $700-800 now?
    Still looking to spend less, while getting bangs out of my bucks.
    #21 zantaff, Jan 7, 2013
  23. Termie
    Aug 17, 2005
    7,858
    40
    You don't need to use the Radeon HD4550. The built-in video on the 3570k is faster.
    So you're set for now - when you have the extra funds together, an HD7850 would be a perfect choice.
  24. zantaff
    zantaff Member
    Jan 5, 2013
    28
    Is the HD 7870 higher price tag not really worth the speed boost, then?
    #23 zantaff, Jan 7, 2013
  25. Termie
    Aug 17, 2005
    7,858
    40
    Depends what you're paying. The 7870 has recently gone up in price. It's now at least $35 more than a 7850. It's about 20% faster at stock. Overclocking is luck of the draw, but the 7850 may have a bit more headroom.
    Given your budget, I'd say the 7850 is the better option.
  26. zantaff
    zantaff Member
    Jan 5, 2013
    28
    So in other words, with OCing the 7850, there's no real world difference between the two.
