- Jun 3, 2005
- 13
- 0
- 0
I had FarCry installed with patch 1.1 and 1.3 about last year a made the switch from 98 to XP. Well i didnt play FarCry much so i went and tried to uninstall the patches then i was going to take the game off. Well... it said it can find the Patches. The game is fine but all the patches and things that came with them are gone. Well i want to play FarCry ONLINE again but i need the patches. So i go and try to reinstall them. It wont let me! it says that i need to unistal them first. I CANT UNINSTAL THEM! so i need some help. please can you tell me what happened to the patch files and tell me how to fix this problem. Thanks, Jake
