- Aug 19, 2016
- 2
- 0
- 6
Hi Everyone!
I am trying to decide on the fan setup for my first build. There are a bunch of fan headers that I could use:
* three 2-pin fan controller headers (Arc Mini R2)
* four 4-pin PWM on the mobo (Asus VIII Gene)
* there will also be two 4-pin PMW on the graphics card (asus 1080 rog strix)
CPU will be watercooled (will have a radiator on top) so I guess the main concern should be the graphics card heat? I was planning to install two front 120mm intake fans and one 120mm exhaust at the back. I could also install a bottom 120mm intake fan - would it be worth it?
So if I get PWM fans, I am not sure whether to use graphics cards headers, mobo headers, or a combination:
* graphics card has two headers, so for three fans I will need a splitter.
* or maybe connect two intake fans to graphics card, and exhaust to mobo (or to controller)?
* or perhaps add a bottom fan and connect it to mobo (so that mobo has control over a bottom intake and an exhaust fan, while gpu controls two front intakes)?
* or maybe I am overthinking it and using mobo headers for all fans is just as good?
Would appreciate any advice
Thank you!
Thank you!
