rallycobra
I have a Netgear N600 WNDR3700 wireless gigabit router that is my primary home network device. It is mounted in a suboptimal location and I would like to extend the wireless range. My house is wired with Ethernet, and I figured I would take one of my old routers (Linksys and Buffalo with dd-wrt firmware) and use one as a wireless access point.
I had no trouble configuring the router as a WAP by disabling DHCP and hooking it to the Ethernet port in a far corner of the house. I used the same password and SSID and everything works. The only problem is that my wireless devices still get enough of a signal out of the N600 they don't switch over to the Buffalo Router WAP.
How do people get devices to switch to the strongest device? Should I create a separate SSID for the WAP like homenetwork2? That might force devices to switch over. I'm primarily using windows laptops, iphones and ipads.
Thanks in advance for your assistance!
