help with epox 8kha+
superflysocal
411
I have had my epox MB and amd xp 1600+ for about a year now. It has worked fine until today i turn it on, and i get nothing except a constant beeping noise.
The only hardware change I have made recently is adding a firewire card 5 days ago but it was working fine.
I did take it out but still no go.
The LED says C1 or CI but i don't know what that means. The manual doesn't help.
I am in the process of removing each card one by one. I also will remove the sinle Crucial 256MB PC2100
Help! Anyone?
mechBgon
Oct 31, 1999
30,699
If it won't even POST, try taking the motherboard out of the case and running it that way, with nothing but the RAM and video card. No drives, etc. That removes some variables. Do you have another compatible system you can test the memory in? Also, what make/model of power supply have you been using... maybe it was chronically overloaded and kicked the bucket?
superflysocal
411
enlight 300w power supply
i will run out to BB to see about getting a replacement 256mb chip. Can I run higher than PC21000 On this board?
Killrose
6,230
8
Almost sounds like bad memory. I have the same set-up. Maybe tonite i'll pull-out my single stick of ram and see what I get.
Killrose
6,230
8
I just pulled my ram out of my 8KHA+ and tried to start it. The fans spin, there is no video, I get a C1 error, and the intermittant long beep. Try another ram slot, but i'd say it's your ram. Lifetime warranty on Crucial.
superflysocal
411
Just went to microcenter and got Centron 256mb ddr pc2100. Stuck it in and still same problem!! Will try other slots.
superflysocal
411
things are looking bad:
tried new vid card rad 7500
new memory centron
unplugged all cards and drives and still no go.
i am left with cpu and MB (no!!!!) unless anybody has a suggestion
guess it could be power supply but everything seems to be fired up and spinning but may not be enough juice.
could it be that centron is incompatible? anyone with centron and 8kha+
mechBgon
Oct 31, 1999
30,699
Maybe go back and trade in the RAM towards an Antec TruePower430 PSU?
superflysocal
411
sorry not nearly as technically inclined. Wouldn't know what to do with a voltmeter.
will probably try to swith out cpu next.
superflysocal
411
I am starting to think ahead; if my MB is dead and i need to replace what are the current recommendations? I would like a rock stable mb with a good reputation. Not into OC. Good feature set would be nice, lots of fr and rear usb for under 100?
Can I use my PC2100 memory in a PC333 board?
superflysocal
411
jamautosound
6,754
Cool a double post 5 days apart!;)
For $75 you could get a A7V266E from newegg.com, I have this board in my son's computer, it's quick and stable.
