Help with Epox 8kha
ChaingKaiShek
12
I recently purchased a new mainboard, memory and cpu. However while glancing over the mainboard memory I noticed that one of the few jumpers the board does have is for 'CPU Host Clock'. Forgive me for being retarded, yet I have no idea if I should leave it at the default 100mhz or set it to 133mhz. I'm leaning towards the 133mhz due to the fact I have an AMD 1.33ghz (266) so it would be quite obvious to set the host clock to 133mhz, right?
Chaing
spazntwich1
Banned
Apr 22, 2001
839
Yup.
Though you might have to start the computer in 100mhz FSB mode first. When I tried starting the computer on a 133 FSB initially, I wouldn't get a POST beep or anything on my monitor. I had to boot it up in 100mhz FSB mode, go into BIOS, set the value for my FSB to 133mhz, save to CMOS, shut down, set the jumper to 133mhz, and restart.
Then it booted fine. Of course, this was with a 1ghz/100mhz athlon, so you will probably be ok.
