Help with Epox 8K7A+ Mobo!
GTaudiophile
29,767
33
What would the multiplier setting be on a 1.4Ghz Athlon for 266Mhz DDR RAM?
Also, where can I find out what the LED codes are?
Hender
647
Assuming you're not overclocking, the 1.4 GHz Athlon with a "266" MHz bus would be a 10.5x133 multiplier. If you're looking for exact motherboard settings, can't help you there. My 8K7A hasn't been ordered yet. :) As for the LED codes, check the manual, they should be in there.
TechGraphix
54
I don't have my manual handy, but if you leave all the dip switches to off (auto mode) it will automatically set to what your processor is set for. For 1400 -- 1400/133 = 10.5 multiplier. Now that I think about it, to override the auto setting I think that switches 1 and 5 on is 10.5. I was just messing with mine last night. Check the book though, there is a nice table with all the settings.
GTaudiophile
29,767
33
I'm helping a friend. The LED codes are not in the manual he says. I'm dealing with him over ICQ.
