"My front usb ports are not working": Are they plugged into the mobo? if so, is hte port jumpered(per manual) to the "on" position?
"usb ports are showing up as 1.1 instead of 2.0.": Make sure you installed the 2.0 driver, if you're running Windows..the driver is usually installed during Windows Update.
