phexac
I just built a new system in the signature.
The important components here are:
C2D E8400 sitting at stock clock under the Tuniq Tower on ASUS P5E X38 board. The case is Cooler Master Stacker 830 with 2 additional 120mm side fans.
I am using 3 different CPU temperature meters: CPUCoo 8.0.6, Core Temp 0.96.1, and SpeedFan 4.33.
Of the two, CPUCooL and SpeedFan match each other almost exactly, going from 35 degreed on idle to 47 on full load running PRIME95 torture test on both cores. CoreTemp is basically 10-12 degrees higher, going frmo 45 to 57 degrees.
Which one is correct? I have read on the AnandTech forum in the overclocking guide that 3.32 SpeedFan underreported C2D temperatures by 15 or degrees. I find it pretty hard to believe that my E8400 is idling at almost 50 degrees Celsius under the Tuniq.
Finally, in AnanTech reviews, CPU temperatures under high-end coolers go from 27 on idle to about 33-35 on full load at stock temperatures, and that is for the E6xxx series chips. I would expect the E8400 45nm part to run lower. I mean it IS THEORETICALLY possible that I screwed up applying the thermal compound to the processor (I used the one that came with the Tuniq, spread it somewhat evenly over the CPU, and slapped the heatsink on...even if I did not spread it too well, the sheer pressure of the heatsink being pushed down by screws should have ensured that the paste is spread evenly...right?).
Any help and comments would be appreciated.
