Help with Dual Channel
Monyet
113
Right now, my PC is on Dual Channel, however, i'm planning to upgrade my RAM to 4GB, do I have to choose the exact same brand, model, and memory specification to run Dual Channel? Right now my RAM is Corsair 2 x 1GB DDR2 667. please help and give suggesiton.. thx
Roguestar
6,045
No. But people will tell you so. Is it a Core 2 Duo you're using? Dual Channel is a bit more forgiving than it's made out to be; but it's easiest to get problemless upgrade if you pick the same memory modules. What you need are: 2GB of DDR2, at least 533. What you want: 2GB Corsair DDR2-667. Newegg has an offer for 2GB Corsair DDR2-800 http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590 . But wait, what's what you say; it's not the same speed? Well don't worry. It'll run at the same speed as the lower-rated modules in the dual-channel setup. And besides, it's probably all running at DDR2-533 speeds anyway if you haven't overclocked or changed memory ratios.
Bottom line: that corsair 2GB kit I linked is probably your best bet for a pain-free upgrade. Don't expect to see more than 3.2GB in windows XP or Vista unless you're using 64-bit, mind. Search the forums for "4gb" and you'll probably find a lot of "why can't windows see all my memory" type threads.
Monyet
113
I'm currently using:
Corsair ValueSelect 1GB x 2 (2GB total) 667
But I'm thinking if I would ever buy the 800 version, is that possible to still run dual channel on my PC?
thesob40
121
if you buy ddr2800 they will run ddr2667 due to your current ram. and yes you could still run dual channel
