Hi
Just setup a new Desktop from components
Intel 4790K CPU
Gigabyte Z97 D3H Motherboard (BIOS ver F7)
2x8 GB DIMMS G.skill Ripjaws 1600 MHz F3-1600C9D-16GXM
2 issues are bugging me :'🙂
1. DRAM is working at 1333 MHz not 1600 (all monitoring software show same value including CPU-Z, and BIOS)
XMP is currently disabled in BIOS (default setting)
Do I need XMP to get it to 1600 M ?
2. Although BIOS detects correct CPU (K version) most of the clock tuning menus (including CPU clock ratio, system memory multiplier etc) are not active. all are set to AUTO and can't seem to change that.
loading default BIOS values does not change situation)
Appreciate your help,
Shalom
Intel 4790K CPU
Shalom
