Help with Dos Commands
Mister T
3,439
I need to copy c:\Mydocs to d:\Mydocs
Directory Mydocs has a bunch of subdirectories and I want to do it with 1 command.
I tried
copy c:\mydocs d:\mydocs
but it only copied files in the root, not any of the subdirectories
how do I modify the command?
Wuming
1,030
try copy c:\Mydocs\. d:\Mydocs?
oh my... haven't used dos commands for so long. tell me if it works okay? :)
piku
4,049
maybe
xcopy c:\mydocs d:\mydocs
haven't used dos in a while... alternatly try
c:\mydocs\*.* d:\mydocs
Whitedog
3,656
I could tell you , but this will do you ever better.. it will "educate" you. ;)
type copy /?
or xcopy /?
This will give you a list of all the avalable "switches" you can use.
The answer is real simple. :)
Whitedog
3,656
OK, I won't be mean.
You have to use XCOPY
xcopy c:\mydocs d:\ /s or /e
(it will create d:\mydocs if doesn't exist)
If you already have a d:\mydocs DIR and type xcopy c:\mydocs d:\mydocs...etc. you'll end up with..
d:\mydocs\mydocs\*
teknoid
468
If you and to keep long filenames (if any) you have to use the following line from the start-run command (NOT a DOS window)
xcopy32 c:\mydocs\*.* d: /h /e /c /k
That will create any and all directories, keep file attributes, ignore "file busy" errors, etc.
Used it many times to clone from one drive to another before I got Ghost.
