Help with determining battery type
Kristi2k
1,364
4
I need to know what kind of battery I have for my NOCO Genius 5 charger.
2012 Honda CRV with a Exide Global Extreme
2022 Toyota Tacoma (not sure what it is)
Is it:
Wet Cell, Gel Cell, Enhanced Flooded, Maintenance-Free and Calcium batteries
AGM?
Assuming it's not lithium.
RLGL
2,115
322
What is the brand and model of the battery, oh wait let me guess...
deadlyapp
6,685
752
Lot of newer cars have AGM, so the Tacoma might have that, your other one is probably a standard wet cell
14,084
Typically it should say somewhere on the battery if it's gel or not. VRLA and AGM are other names they may go by. They are slightly different techs but basically would fall under Gel.
If there are caps on the battery that are easily removed then it's probably a wet cell. If you need more than light force to pry them open then don't try further, as even sealed types may have caps but those are not meant to be opened.
If it is in fact a wet cell then make sure to actually check it once in a while as you may need to add distilled water if you see the water level is low. If cared for, wet cells will last a very long time.
deadlyapp
6,685
752
AFAIK AGM doesn't inherently mean gel. AGM just means absorbed glass mat and most are still lead plates and flooded.
