So I am currently running an older system based off an Intel Core 2 Duo QX6800 OC'd to 3.2ghz and 1066mhz DDR2 and a GTX 460.
I was holding out for Sandy-E in hopes of putting together something akin to a 3600k system, but as the launch day approached I saw that the Sandy-E was really more of a sole replacement for Extreme chips and that there would only be 3 chips. The only real option for me being the $550 3930k. Reviews have been kinda mixed though with how Sandy-E isn't really an improvement in terms of gaming or everyday applications. Basically if your program isn't heavily threaded or a memory hog SB >= SB-E for half the price.
I read into Ivy Bridge then, which appears to be the mainstream successor to SB, but most of its improvements don't seem to be worth waiting for me. I don't have alot of SATA devices and I don't run a multi-monitor setup, or ever do anything beyond basic SLi. So it seems the SATA and PCI-e upgrades Ivy boards are boasting might not be worth the price for me, especially since the memory is staying the same dual channel. I also read that Ivy chips will be backwards compatible with some of the more high end LG1155 boards that are out already.
So now I am wondering what you all think about building a system around a 2600k, and simply swapping the chip out to an Ivy Bridge if they really are 20-30% better in performance? Or should I just wait for the Ivy Bridge to hit in March and build a system around the "3600k" and one of the new boards?
