Anyone know how to take this thing apart? I want to get at the hard drive, and have removed all the screws on the bottom, but can't get the laptop casing to seperate.. Is there some trick? Something I am missing? Anyone know?
If I remember correctly, there is no need to take to entire cover off.
There should be 2 screws on the left side of the laptop (raised portion where the audio ports are).
Unscrew those and pop the cover and pull on plastic handle to remove drive.
