T
Tim
I have an e8400 with a Thermaltake Bigwater 760i hooked up to it and I'm using AS5 as the thermal compound.
My system specs can been seen from a link in my sig.
Running at stock speed and 1.168v (according to cpuz), My idle tems are anywhere from 26-29 idle, 34-39 load (running orthos and super pi)
I'm also not sure how accurate these temp readings are in the first place.
My case has adequate airflow (4 120mm intake fans, 1 120mm exhaust, and the powersupply exhaust, an and OCZ memory fan kit) Of course I'm keeping the bigwater, as I don't have a huge budget for better water cooling, but I was wondering would it be helpful to get a different waterblock? Also is there a better thermal paste than AS5? And lastly, I'd prefere not to lap the heat spreader, because doesn't that hurt the resale value of the processor if I wish to sell it down the road? Or is that a dumb assumption on my part?
In either case, with what I have, and about 50-70 to spend, whats the best things I can do to shave some degrees off of my numbers, and what can I realistically expect my best results to be with you peoples suggestions?
