This is the first rig I'm going to build.
I already have these parts:
AMD 2500+ Barton
Abit NF7-S ver 2.0
Radeon 9500 softmodable to 9700
WD SE 80GIG 7200RPM, 8mb
I'm looking to overclock:
1. AMD 2500 to a 3200
2. ATI 9500 to 9700 Pro speeds or more
3. Has to be quiet, does not need to be silent - going to have pc in bedroom
Processor cooling:
Heatsink
Set on getting a Thermalright. Should I splurg an extra $5 for a SP97?
Thermalright SP97
Thermalright SLK900
Fan
Would 43 CFM be adequate to cool an overclocked 2500? If not considering getting a Vantec Tornado with a fan controller?
90mm Panaflo FBA09A12L - 42.7CFM @ 27DBA hydro wave bearing
92mm Vantec Tornado TD9238H - 119 CFM @ 56DBA dual ball bearing
Vid cooling:
Going to modify a 1u rackmount cooler. Which should I choose? Does it matter if the Dynatron has dual bearings?
Dynatron DC1206BM-R1 - 24.4CFM @ 40DBA dual ball bearing
Thermaltake A1151 - 23.5CFM @ 39DBA ball bearing
Mobo Northbridge cooling:
Vantec Iceberq CCB-A1C - 3.5CFM @ 26DBA ball bearing
Mobo Southbridge cooling:
Which would work better - stock fan or a passive heatsink?
Abit stock Northbridge cooler
Zalman passive heatsink
AMD 2500+ Barton
Abit NF7-S ver 2.0
Processor cooling:
Heatsink
Thermalright SP97
Thermalright SLK900
Fan
Vid cooling:
