😕 OK... so maybe I'm exaggerating a little, but I need a little help/some suggestions as to what I should be looking to get to lower my case and CPU temps. Here's what I have (newly built):
Abit IS7 Mobo
Intel P4 2.6Ghz (running default) 800Mhz FSB
Retail Box (Stock) Cooling Fan CPU
Stock 80mm standard Case Fan (Front Intake) 3125rpm (REALLY LOUD... ugh)
400W PS exhaust fan 2345rpm
Standard chipset fan... bla bla bla...
SpeedFan and Sandra both have the CPU running btw 54C (idle) and 60C (load) and case temp is maintaining around 50C. Now, I haven't yet started overclocking, but I just know that I'm going to run into trouble since these temps already seem high. I definitely think I'm going to get rid of that stock thermal tape and put some thermal grease on the CPU, but I doubt that it will help more than a few degrees. Case isn't easily maneuverable, the PS is about an inch over from the CPU fan (I've got cables and PCI cards well managed and out of the way of airflow), and I may be looking at adding another fan - but at the cost of more noise???? - I was looking into those fans that exhaust from a rear expansion slot, but I'm not sure if they will do the trick. Any suggestions would be greatly appreciated. Thanks!!
Abit IS7 Mobo
