Help with cooler/thermal compound advice for i7 860
ekoostik
I'm buying components for my first build, a new i7 860. Something I had not considered until recently is the thermal paste. Do I need to buy some paste to use with the stock cooler? If so, what would you recommend?
If you do recommend it - since I was not planning on buying a separate cooler now, if I did choose to get one at some point, would it be easy to clean the thermal paste off the CPU and stock cooler? What is the process?
Or, would you recommend getting the a new cooler now? If so, what do you recommend? Part of the reason I was going to hold off was there does not seem to be too many options available yet. I'm also not sure if I'm going to overclock the CPU. I'm waiting for good reviews of the benefits & work involved.
1) Stock cooler has thermal paste on it. It's the gray strips.
2) It's easy to clean off. Get some lint-free synthetic cloth and wipe it off and clean with some 91% isopropyl available at your local pharmacy.
3) You can get one now, or you can wait. It's personal preference if you want to take the board out and put a back-plate in later for a 3rd-party cooler. Or you could just pick up one now. If you get a board with LGA 775 mounts, you can pick up any of the old coolers for 775 (MSI and EVGA have this, I think).
