Help with computer issue
acebake
936
The other day, I went to one of the computers upstairs. When I went to turn it on, it showed the "Windows did not start successfully screen," and gave me the usual options. I've tried all of them, and it's just looping back to the same screen. What is happening?
acebake
936
No, but my CD-ROM drive lights up constantly during the whole process. Any ideas?
Thanks for the advice!
Markfw
May 16, 2002
27,426
16,292
More information please... Machine specs, did you add something recently, other history ??? Is a reformat even a possibility ? How new ?
acebake
936
It's very new, I built the system at Christmas.
Specs:
AMD Athlon 1 GHz
512 MB PC133 SDRAM
10 GB HD
CD-ROM
I know it's not a particularly speedy machine, but it's for someone who just does email and internet. A reformat could be a possibility, but I only have one Windows XP Pro CD....what is the license governing that? I was installing it last night, and from what I gathered, it could be on two computers at any given time, no more. Is that correct?
Thanks!
mechBgon
Oct 31, 1999
30,699
Specs:
AMD Athlon 1 GHz
512 MB PC133 SDRAM
10 GB HD
CD-ROM
Thanks!
Search your hard drive for "EULA" and I believe you'll find your license terms allow using it on only one computer at a time. The computer may have either one or two processors in it, however. As for the problem, I wouldn't fight with it, I'd reinstall (if I had a license to).
acebake
936
I wanted to make a quick edit: it's Windows XP Professional. I don't know if that makes any difference....
Thanks for the advice! :)
Jiggz
4,329
Press F8 when you see the Splash screen and then choose Safe Mode. Does it boot at safe mode? If it still would not boot at safe mode you would have to re-install. Try repair installation first see if that will fix the problem. If not you will have to do a full reinstallation.
