Help with computer audio hardware
grohl
2,849
I had a sweet 7.1 Gigaworks system that was $400+ and was awesome and of course total overkill. Then the sub module blew - searched for all kinds of DIY ways of fixing it and even took it to an electronics repair place. It's dead. Creative doesn't even offer a repair.
So now I've got 6 speakers and a center channel that of course works fine. I do not have another sub or spare receiver to piece together a 5.1 system.
I'm guessing my only options are to buy a whole other system or a used system. The best thing would be to find a controller/sub without satellite speakers, used. Money is a bit tighter than it was way back when too.
Any thoughts? Looking to spend $150 or so. And 5.1 is plenty.
mfenn
22,400
www.mfenn.com
How do the speakers connect to the sub? If it is just normal speaker wire, get a cheap A/V receiver and you're all set.
grohl
2,849
I also need a cheap sub then. Problem is, can I get a receiver/sub for <$150 that's worth a damn?
