Hi all!
First of all, this is not homework, it is a review for Final exam, I do not get extra credits for completing it (the review), or anything like that.
My coursecompass.com account expired today, and I can't use it for studying
I have 60 problems on review, and I just did 30 (used 12 sheets of printer paper for scratching). On couple of them, my answer != answer in the answer key. Some explanations and help will be appreciated :thumbsup:
#7)
3 + sqrt(x+3) = x
Find x.
I calculated that x = -3 and x = -4, but they both do not check. Answer key says x = 6, and 6 checks, but how to get 6?
Solved it again, using quadratic formula, and answers are -2 and -7/2 :roll:
#9)
(x+28)/(x+1) < 4
I can understand x != -1, but how did they get x !=8? What were the steps?
#19)
Find slope and y-intercept.
x-5y - 5 = 0
This is probably so simple it's humiliating. What are the STEPS to finding slope and y-int? I do not need the answer, it's already given in answer key (slope = 1/5 and y-int (0,-1)).
#20)
Write the equation of the line in standard form.
x-int is -5
y-int is 3
I know std form is Ax+By = C, but I do not understand how to go about the steps? Answer is (3x-5y = -15).
#29)
The base and height of a triangle must have a sum of 40 inches. Find the base and height of the triangle whose area is as large as possible.
This is probably also dead simple, but I am stuck. I know that
b+h = 40
Area = 0.5 * bh
Answer is base 20 in, height 20 in.
Here's the PDF with review:
Text
Thanks for your help, o allmighty math gurus! And may your respect++
#7)
3 + sqrt(x+3) = x
Find x.
#9)
(x+28)/(x+1) < 4
#19)
x-5y - 5 = 0
#20)
x-int is -5
y-int is 3
#29)
b+h = 40
Area = 0.5 * bh
Text
