Group,
So I picked up a new samsung hd from newegg. A SAMSUNG SpinPoint T Series HD501LJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive. I tried to install this last night. Hitting a problem. I don't have much experience with changing drives. Not sure if I have a bad drive....
How often does getting a bad drive out of the box happen?
I am trying to clone the new samsung to replace the maxtor as my systems primary c drive.
What is happening to me is:
My system is a Dell 8400 with a maxtor 500g as the primary drive, and a 160 segate as a secondary, both are sata. I am trying to replace the maxtor with the quieter, cooler Samsung. I cracked the case, plugged in the samsung and booted. All worked so far. Then I used maxblast to clone the maxtor primary drive to the new samsung. I left the samsung as a secondary drive and ran some tests. all seemed well. Then I switched the samsung to be the primary c drive and the maxtor as a secondary drive. I then tried to run some speed tests and hit several bsod (blue screen of death) crashes. I tried forcing the samsung to be 150 sata connection, but that did not seem to work. I ran a chckdsk on the samnung and it showed multiple issues. So I started from scratch again. Re cloning the maxtor to the samsung. Same result the clone would work well until i switched it to be the primary.... So it was getting late and switched the samasung back to a secondary drive, removed the 160g segate and just did a plain old format on the samsung last night. It was still running when I went to bed. This morning, it was finished with no errors. So I started a utility to check for errors (hd tune I think i was called) Will check into it after work today. Anyway, i need to return the maxtor by tommorow. Fry's 15 day return policy (yuck) but I am not sure I have a bad drive, or something else is a problem. Have I missed anything? One thought was maybe i was over taxing the powersupply with the 3 sata's connected?
Any pointers?
Thanks.
--pat
Any pointers?
Thanks.
--pat
