Maverick07
Okay, I had one of my servers crash, so I had to load the backup onto my second server (Windows 2000). My DNS was also ran on the server that crashed so I'm pointing everyone to another DNS server that we can use. Everyone is mapped to the new drives containing the first servers files.
Clients are using XP and 2000. Some have roaming profiles and others do not. I have two users on two machines and I can not get them to log onto the network properly. For user A (XP), when logging in they get a message saying that the computer can not locate the profile on the server. I have checked the path in the Active Directory and it's fine. If you scroll down, there is more information saying detail and a compromised security issue. So if you press ok, they log on with the local cached profile. I then try and map a network drive, but the computer just sits there and then a minute later (about) I am presented with a logon box. If I put in User A's log in information, I get a message saying the computer already tried that. I can not even use the administrator log in information. I get an error message with that too. What's going on here?
I do have an error in my Event Viewer on the server:
No Windows NT or Windows 2000 Domain Controller is available for domain XXXXXX. The following error occurred:
There are currently no logon servers available to service the logon request.
Now the second user can log in just fine, profile loads (takes forever though), but has the same problem as User A when mapping the drives.
Any ideas or things I should check? I'm at a loss here. The other users in the building with roaming profiles, their profiles are taking forever to load and I have cleared the temp internet files for them.
Thanks,
Lance
Thanks,
Lance
