Well, I have a rebranded Clevo P170EM and since I reformted it I'm having all sort of problems (the f..ink laptops are gonna drive me crazy😡 Can't they just work like the desktops?).
I think (I'm pretty sure actually) that I've installed all the drivers for this model and they're up to date, but I'm havin 3 issues right now. I'm really ofuscated with this laptop so even if you think that it might something really basic say it because I've reinstalled everything so many times that I might be forgetting something:
-If it suspends it doesn't come back. I think that the laptop actually gets off suspension but I don't get screen output.
-When it's idle and the screen turns black the the fans go to maximum speed without aparent reason, once you move the mouse or touch any key they spin down.
-Virtualbox doesn't recognize the laptop as x64, so maybe Vt-x is not working? I checked the BIOS, but it's a AMI that's as shitty as it gets, so no option to enable/disable virtualization.
If you're interested in the specs (just what might be relevant, to keep it short):
-i7 3740qm
-16GB DDR3 1600
-GTX680m
-120GB SSD
-750GB HDD
Appart from that just one advice: if someone is looking for a laptop like that, just forget about it if you can get by with something else. It's powerful, yes, but appart from that it's an overpriced pice of crap.
-i7 3740qm
-16GB DDR3 1600
-GTX680m
-120GB SSD
-750GB HDD
