I installed a new 10/100/1000 blade in my 4006 switch, set a VLAN on all of the ports, enabled portfast on all ports and connected PCs to the 10/100 ports. The PCs were not able to get an address from the DHCP server unless they were rebooted multiple times. I thought enabling portfast was supposed to solve that. I then added port channel mode off to all ports and now all PCs can connect. I'm not sure if that command did anything or if it's just because the PCs have been rebooted. Any ideas what is causing this problem?
Thanks.
Thanks.
