DPOverLord
I will be using this computer with the following components:
Venice 3200
Ram : Wanted CSB since 80$ for 1GB
Power Supply: Looking at Antec TruePower 510 Watt(90$ instead of 220 for PC P&C 510)
Video Card: GF 6800GT or ATI x800XT/XL
I plan on possibily o/c the cpu (not the ram) to a higher spec at some point since I heard the venice 3200 o/c's nicely. I was leanign towards the Ultra-D until I found out the the Corsair Value select ram may not work with it. I found this to be steal for 90$ and still have not found anything in that category. I am still undecided on what card I will buy and the Power supply. I am looking at spending less than 1k on this system and Really need help from all of you hardware gurus on that mobo. What do you think would be the best choice?
Thanks!
Venice 3200
Thanks!
