Help with choosing a case
rampage42
42
I'm building a new computer - a performance/gaming based one. So far, I'm choosing some parts and stuff, here's the list.
Its subject to change, so please make any suggestions that you think of.
PSU - 800w Quiet PSU - http://www.internetct.co.uk/80...twin80mmfan-p-366.html - £27.03
Mobo - ASUS STRIKER II FORMULA - http://www.lambda-tek.com/computing/pcdesigner.htm - £148.19
CPU - Intel Core 2 Duo E8400 3.0Ghz - http://www.eclipsecomputers.co...ct.aspx?code=CPI-E8400 - £126.44
GPU - NVIDIA 9800GT - http://www.eclipsecomputers.co...ode=GC-XN98GT512&af=50 - £71.59
HDD - SAMSUNG 750GB 32mb SATA - http://www.lambda-tek.com/computing/pcdesigner.htm - £47.56
RAM - EBAY - http://shop.ebay.co.uk/items/?...2GB+DDR2+RAM&_osacat=0 - 4GB £26 approx
Optical - LG GH-22NP20 - http://www.eclipsecomputers.co...ode=DRL-GH22NP20&af=50 - £19.26
My budget is going to be around the £500 mark. Can you suggest a good case + fans for this setup?
z1ggy
10,010
66
PSU too big..you only will need a 500w.
Don't know if you can shop on newegg.com but I have the antec 900 and I love it. Also the HAF gets good ratings. Your prob. going to want a mid tower with about 4 fans. Also if you OC get a good HSF as well. Also..if this is gaming you may want a better gpu. Depending on what res. you use..get a 4870 or 4890 ( or its equiv.)
SKRZYCKISKI
4
This case you should never out grow with air cooling, includes fans
Starting at: $179.99 at performancePC.com
Cooler Master SGC-6000-KKN1-GP CM Storm Sniper Case - Black
The Cooler Master Storm Sniper is a cool mid tower case designed with purpose and efficiency in mind. The rugged exterior inspired by military weapons help give away its durable and high cooling potential! Three huge internal fans help keep your system ice cold. The convenience of a handle and foot stands allow for a stable base and easy portability. The cavernous interior makes sure all of your top end gaming gear has a place and has enough airflow from every angle. If gaming is on your mind look no further than the Cooler Master Storm Sniper!
Features:
Fierce exterior design inspired by military weapons.
Unprecedented airflow from up to 3 huge fans.
Next generation control center for tuning your lights and fans.
StormGuard ? ground-breaking security system for safeguarding your gaming peripherals.
Convenient handle and foot stand for fast and efficient mobilization and relocation.
Screw-less design for quick upgrades and maintenance.
Specifications:
Model SGC-6000-KKN1-GP
Available Color Black
Material Steel, ABS Plastic, Mesh bezel
Dimension (L)22.3 x (W)10 x (H)21.7 inches
or
(L)566.6 x (W)254.6 X (H)551 mm
Weight 23.42 lbs
or
10.6 kg
M/B Type Micro-ATX/ATX
5.25" Drive Bay 5 Exposed (without the use of exposed 3.5 inch Drive Bay)
3.5" Drive Bay 5 Hidden 1 Exposed (converted from one 5.25 inch Drive Bay)
Cooling System Front: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA)
Top: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA)
(can be swapped for two 120mm fans or 120x240mm Radiator)
Rear: 120x25mm Standard Fan x 1 (1200rpm, 17 dBA)
(can be swapped for 90mm fan or 80mm fan)
Bottom: Supports 140mm Fan x 1 or 120mm Fan x 1 w/ Dust Filter (optional)
Side: Supports 200x30mm Fan x 1 (optional)
120x25mm Fan x 2 (optional)
Expansion Slots Standard x 7, Special x 1
I/O Panel USB2.0 x 4; IEEE1394 x 1; eSATA x 1; Mic x 1; HD Audio+AC?97 x 1
Power Supply Standard ATX PS2 / EPS 12V (not included)
UPC Code 884102003752
Reviews:
3dgameman - 100% KICKASS 3dgameman.com : January 2009
"The Cooler Master Storm Sniper Case is feature for feature one of the very best mid-tower cases on the market. With three fans (2x200mm & 1x120mm) it has excellent air circulation, tool-less design, quality build, excellent styling, etc. It even comes with integrated handles at the top. This is the case you've been looking for! Watch the video to find out more..."
» Details
Benchmarkreviews.com : January 2009
"In terms of its cooling capability, the Sniper bested an old favorite of mine, the Antec P180 series. The open mesh design and 200mm fans, offer incredible cooling performance without sacrificing noise levels. If this is any indication of the things to come, the CM Storm division may quickly become a new favorite among gamers and enthusiasts."
» Details
Hardwarezone: 4 (Very Good) hardwarezone.com : January 2009
"...it is a solid offering from Cooler Master and one that we suspect will find its way into the homes of many gamers."
» Details
Eureka
3,822
The Antec P18x series also tend to be pretty good cases. Or the Gigabyte 3D-Mars.
You also can't go wrong with a Lian-Li or Silverstone case. The LIAN LI PC-A70B or SILVERSTONE TJ09-BW are nice cases.
Tullphan
3,507
Yeah, if you can shop Newegg, i'd do that. I followed your link to the PSU & of all the ones listed, all but 4, I believe, had brand names (the 4 being CoolerMaster & Thermaltake).
I did a search on Newegg for cases that included PSU's (specifically Antec) & they had a Sonata Plus for $119.99. It includes a 550W NeoPower modular PSU. A good quality case & a decent name-brand PSU.
That should be sufficient for you.
