Help with CD Writer!!
susantor
32
Hi, I have a question about copying a cd. Can I use other programs while I copy a cd? For example: Can I browse Internet, play game or using microsoft word while I am copying a cd? Is it going to affect the quality of the cd?
NeoMadHatter
2,355
johntwang.com
sure, if you can. i'd suggest having a burnproof drive if you're doing this. sometimes the buffer goes wierd and you make coasters. and it should not have any effect on the cd. i burn my cds while playing mp3s, going on website, talking on AIM, and sometimes playing games. and so far no problems.
blackhawk
2,690
Burnproof or scsi should allow that. Try it on something that's not critical and see if it works for you.
TheYetiMan
42
I do it all the time with no problems and friends of mine freak out over it.
I have burn proof and a boatload of ram (1.5gig). CloneCD shows the buffer states on the fly, and rarely does the buffer react any differently than when it is the only operation going on.
MrDudeMan
15,069
94
it all depends on the burner and how fast your system is...if you have resources to spare, then you can do other stuff, if you dont, and you dont have burnproof or anything to that effect, then you cant
