Hi guys,
I'm coming to the end of the new build, and all that's left is choosing a good case to put everything in. First, let me summarize the hardware that will be going in:
Maximus VI Extreme mobo
I7 4770k
Zalman CNP9900 heatsink
Sapphire HD 7970 x1
SSD x2
HDD x2
Corsair 1200i PSU
Corsair Dominator platinum 32gb
Several Noctua 120mm fans
A few points on intended usage:
1. Not planning to go for water cooling to start, so I'm looking for good air flow/support for additional fans, might look into water cooling if the air-cooling doesn't cut it
2. In the future I foresee going with a multi-GPU setup, and potentially a larger motherboard to support more RAM
3. Some of the parts (especially the GPU and heatsink) have a long form factor or significant depth
Budget I'm looking at is anything up to $250 or so, I favor a half or full tower design, something sturdy that will keep the components managed well (wire management, ease to swap/add components, air filtering, easy to open etc).
I've seen some interesting cases from Corsair, Silverstone and Cooler Master, what would you guys go for if you were building this?
I7 4770k
Sapphire HD 7970 x1
SSD x2
HDD x2
Corsair 1200i PSU
