Rakewell
Greetings all,
I am building a computer for my folks... Can anyone recommend a cheap case/PSU combo for the following setup:
ASUS "A7N8X-E Deluxe" nForce2 Ultra 400 Chipset Motherboard
AMD Athlon XP 2700+, 333MHz FSB, 256K Cache (Thoroughbred)
Corsair Value Select 184 Pin 512MB DDR PC-3200
Hitachi 160GB 7200RPM SATA Hard Drive
eVGA nVIDIA GeForce FX5500 Video Card, 256MB DDR, 128-bit, 8X AGP
I was thinking of the RAIDMAX Diamond Series Mid-Tower Case with 350W Power Supply for the case/psu... do you think it will be enough power, and reliable?
http://www.newegg.com/app/viewProductDesc.asp?description=11-156-112&depa=0
Also, what do you guys think of their setup? They aren't gamers, but they do plan on doing minor DV editing (home movies and such).
Thanks,
Rakewell
Thanks,
Rakewell
