I have a watercooling setup and I need help placing a case fan. I'm not sure if it should be blowing In, right on the radiator or out sucking air out over the radiator. Just about all the components are actively cooled.
Here is my current setup (note, i do have a SB fan as well that I forgot to put on it), I know it's messy but my temps really arnt' that bad. It's hard to see from the picture but the radiator is actually on top of a spacer, so air does get under there pretty well. My problem is that with the case on, and my room at 90F the temps get up there. AirFlow
(1) Should I put a fan Here blowing In, our Out?
(2) or should I put it Here blow out?
If it helps at all, here are some more various thumbnailed
pix
Thanks much!
Sokratz
pix
Thanks much!
Sokratz
