Here is a quick description of my setup :
Antec 1080 AMG
Antec True 480
Soyo Dragon Platinum
Athlon XP 2400+
Athlon XP Shim
MCX462+ Heatsink
Thermaltake Smart Fans (2)
Mushkin 512MB Hi Perf Level 2
PC2700 DDR 222 (1)
Toshiba DVD 16x SD-M1712
Plextor CD-R 48x
Zip 100
I have one Thermaltake Smart Fan on the Heatsink and another in the front of the case - the (2) rear fans are "stock"...
I am about to add the following right away :
GAINWARD/CARDEXPERT GeForce 4, 8X AGP. Ti 4200,
3.6ns, 128MB DDR, Power Pack Golden Sample
ALSO : Thermaltake BLUE ORB VGA Chip / GPU Fan, heatsink + fan (add to the MotherBoard)
ALSO : Going to do a "RAID" w/WD WESTERN DIGITAL "SPECIAL EDITION" 80GB 7200RPM...8mb (2)
SO - I was wanting suggestions on adding fans...I have about (6) Thermaltake Smart Fan II's here available to me....I was considering using "all" of them in the setup ?
Any suggestions or comments about the setup would be greatly appreciated ! Which fans would you run from the Power Supply, and which from the MotherBoard, and what "settings" you would use with each of the Smart Fan II configurations (believe they can be set up 3 different ways), etc. Also, just where would you run all the sensors and such ?
The case sits in a desk and has restricted airflow around the case itself ---- The corner of the room doesn't get much a/c flow, so it is a bit warmer than the interior temps of the room which is about 75º right now...I believe I am pretty much in a situation with restricted airflow "around" the case, but any help would be greatly appreciated.
Temps from the SOYO software read the following :
SOYO Monitor
THANKS !!!
Antec 1080 AMG
Antec True 480
Athlon XP 2400+
Athlon XP Shim
MCX462+ Heatsink
PC2700 DDR 222 (1)
Plextor CD-R 48x
Zip 100
SOYO Monitor
THANKS !!!
