Help with case and cables?
Did you watch the video on newegg about the case?
Your only issue would be the 8pin cpu connector being too short on your power supply. The case includes 2 extension cables it looks like. It's just a matter if you wanna run it behind the motherboard tray or not. !'ve used one extension before without issue but not sure if I'd wanna run 2 of them.
What PSU do you have? Some PSUs like NZXT Hale have a very long (70cm) EPS cable which should be long enough. Otherwise just use an extension, it's not a big deal.
