Help with cable/hub/router/switch/ ham sandwich
scm518
237
Okay I'm eating the ham sandwich -- so consider that a non-issue.
Okay I have my Motorola SB 4100 cable modem from Optimum Online. I have 2 computers each with a NIC - and a friend told me that I should just buy a "switch" and I could hook it all up (2 Nics to switch --- switch to cable modem) and i would be all set. However, I do need a router, correct? If this is true can someone please confirm this, and secondly can you let me know how I should be hooking all this up. I would love for this all to work "out of box" Trying to keep expenses low, so if you can suggest something lemme know.
would it be like this?
(2) computer w/ nics ----> switch ----> router ---->cable modem.
What was, if any, the benefit of buying the switch??
Lastly how many crossover cables should I need with the best possible configuration that I can do with your suggestions.
Thanks and sorry for so many questions...
Sean
Thyme
2,330
That depends on the cable company. You need to ask if you you need to route the IP addresses yourself or if they provide you with multiple ones.
Burn
I think I know what your problem is. You cut the ham sandwich into squares instead of triangles; didn't you? Rookie mistake... :p
scm518
237
Indeed, my ham was square.
I have optimum online -- dynamic Ip address -- doh I apparently dont know enough to help the people that are trying to help me -- anyone else can give it a shot too =)
(_8u(|)
TunaBoo
3,280
Get a netgear RT314, built in 4 port switch/router cable.
OR buy a router and a switch. All ya need is 1 crossover which came with my router (nethear rt311)
Journeyman
354
You only need the switch if you buy a single port router. Simplify things and get yourself a multi-port router - it'll most likely be less expensive, too (multi-port router vs router + switch + cable to go between). Otherwise your diagram is sound.
- Uninstall any software the cable modem company gave you (you won't need it, and it might interfere with your new setup).
- Cat 5 runs from the cable modem to the uplink on the router, and from each computer's NIC to the ports on the router.
- Ensure each computer is set up for DDNS (lets the router assign the IPs).
- Follow the router instructions to allow it to login to your cable provider (using PPPoE or whatever).
Simple, quick, and effective.
Seems your two best choices in a router would be the Netgear (RT314) or the SMC Barracade.
Have fun!
splice
1,275
OK I think I know what you are asking...You currently have 2 computers each with a NIC... and you have not bought a switch or router. Assuming this is correct all you would need to buy is a Linksys 4Port DSL router. It has 1 WAN port for your external modem and 4 10/100 ports on the router's built-in switch for the 2 computers which will be on your LAN. That should be all you need to buy.
