BasariStudios
Hello all, i need some serious help, i need a secondary external
hard drive which will be mirored (or manually copied) from my
existing EX HDD. What do i do with it:
I usuallly back up or use large files, in the GIGS up to 10-15
gigs a file sometimes. The HDD will not be just a BACK UP AND
SHUT OFF but a lot of times will be on for a whole day, reading
directly from it or sitting idle. I would love if it has both, USB
and sATA...what would the advantage of FW400-800 be over the
other? Since few of that have the FW option too. Basically it will
be an everyday use HDD which will not be moved around.
Other features i like would be HOT SWAPABLE and also if possible
easy access to the actual HDDs for exchange and stuff.
It has to be 2TB or around 2 TB. I would appreciate any ideas and
recomendations...around 200$ if possible.
Any of these recomended:
http://www.newegg.com/Product/Produc...%20%2f%20eSATA
Thank You ALL!
Thank You ALL!
