Hey guys this is my first time building a pc. Ive spent a bit of time researching and choosing parts but i'm very new to this.
1. What YOUR PC will be used for.
Gaming - bf3 etc
2. What YOUR budget is.
Preferably under £700
3. What country YOU will be buying YOUR parts from.
UK
4. IF YOU have a brand preference.
Prefer Intel and nVidia
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
No current parts
7. IF YOU plan on overclocking or run the system at default speeds.
Would like to be able to overclock in the future
8. What resolution will you be using?
1920 × 1080
9. WHEN do you plan to build it?
In about 3 weeks
These are the parts which I have been looking at:
CPU: i5-3570k - £175 (only £10 more than 2500K)
GPU: Asus nVIDIA GeForce GTX 560 TI Direct II TOP 1GB £180
or MSI nVIDIA GTX 560 TI Twin Frozr II 1GB £163
(seems to be the best price to performance card)
Motherboard: P8Z77-M PRO £113
(£50 cheaper than the full size board - can still go sli in the future)
Case: NZXT phantom 410 £80
RAM: 2x4gb Corsair Vengeance 1600Mhz £41
HDD: Western Digital Caviar Blue 500Gb SATA3 £52
PSU: Corsair GS800 800W £83
Drive: Asus DRW-24B5ST 24x £14
Total: £721 - £738
All the prices are from amazon uk.
I plan to buy another 560ti in a year or so.
I was just wondering if you guys could tell me if I have made any huge silly errors or if there is a much better (or cheaper) option that I should be looking at.
The components above are slightly more expensive than i would like but if its going to run games well, be able to oc and have good upgradeability im willing to spend a few extra pounds.
Thanks very much in advance
Gaming - bf3 etc
UK
No current parts
1920 × 1080
In about 3 weeks
Total: £721 - £738
