I'm installing an athlon xp system. I'm having a headache with plugging in the case power/reset switch and leds. On the motherboard it's 2 large rows of metal sticks and the manual tells exactly which one should be plugged into which one. And some of what's said in the manual doesn't even match with what says on the connectors. And even with the power switch plug, it goes very detailed into which bar is for ground, and which is for what. So it sounds like if I plugged it in the wrong direction then they computer shouldn't start. But when I watched the guy in the computer store do it before, he just grabbed all of them and plugged in randomly and it worked ok. And I have tried to switch the direction of the power plug on the athlon 64 system and it still worked. So does those frontal plugs even matter in their order?
