totalcommand
Hi Guys,
I'm looking for suggestions on this build.
Thanks!
EDIT:
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming, office programs, internet
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1000 limit
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
None
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
No
6. IF YOU have searched and/or read similar threads.
Yes
7. IF YOU plan on overclocking or run the system at default speeds.
Not sure yet
8. WHEN do you plan to build it?
This summer
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel , SECC Chassis ATX Mid Tower Computer Case - Retail
$49.99
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - Retail
$149.99
ASUS EAH4850/HTDI/512M Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
$194.99
Antec EA650 650W ATX12V Ver.2.2 / EPS12V version 2.91 Power Supply - Retail
$99.99
Intel Core 2 Duo E6750 Conroe 2.66GHz LGA 775 65W Dual-Core Processor Model BX80557E6750 - Retail
$177.99
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK - Retail
$104.99
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
$84.99
LITE-ON 20X DVD±R DVD Burner Black IDE Model DH-20A4P-04 - OEM
$22.99
Subtotal: $885.92
Thanks!
EDIT:
$1000 limit
USA
None
No
Yes
Not sure yet
This summer
$49.99
$149.99
$194.99
$99.99
$177.99
$104.99
$84.99
$22.99
Subtotal: $885.92
