- Nov 29, 2005
- 270
- 0
- 0
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
gaming.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
im looking to build this as an interim machine before putting together a serious system in another year or so. so, for now im going as cheap as possible. $500 or less would be awesome if that is even possible.
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
dont care, whatever gives best bang for the buck
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
BFG has an awesome deal where you can send in your shitty old AGP card(in my case, a 6800gt) and for $50 they will send you a 9800gt! so i will be using the 9800gt.
6. IF YOU have searched and/or read similar threads.
yes
7. IF YOU plan on overclocking or run the system at default speeds.
default speeds
8. WHEN do you plan to build it?
now.
right now im using an athlon 3200+, geforce 6800gt, 1 gig of ram...its old and since i just got a new monitor, im looking to upgrade to something that can handle the now higher resolution i like to play at(1680x1050). i dont need bleeding edge because i really mostly just play WoW and source engine games which run pretty well on average hardware. the purpose of this system is just to give me a little boost for the next year or so before i shell out some big bucks for a really nice machine.
basically i am set on using an athlon x2 6000+ since newegg has it for $72, and the 9800gt because i can get it for only $50. so that is $122 for both processor and video card. as for harddrive, anything around 250gigs is plenty. i want 2gig of ram. 2 disk drives(dvd rw and the other can be just a cdrw). im fine with onboard sound and onboard network card if it is a gigabyte card, but im clueless as to which motherboard and powersupply to choose. as for case, i dont care about looks, something cool and spacious enough for future upgrades would be nice. i think that about covers it. thanks for the help.
gaming.
USA
yes
default speeds
now.
