Help with Budget Build - As cheap as possible
KingstonU
1,405
16
My gf's laptop is on it's last legs and she needs a replacement for as cheap as possible. She wants a desktop. Used for web-surfing, MSN, movies, music, burning DVD's, flash games.
She already has Monitor, Keyboard, Mouse and Speakers.
Target Specs:
500GB HDD
4GB DDR3
Better CPU than current Turion X2 TL-64
Win7
DVD Burner
Integrated graphics (I assume this will be good enough)
Budget: As cheap as possible but will consider an upgrade if it offers substantial improvement for the money. Max $500 CA if possible.
I have been somewhat out of the loop since I built my Q9550. And even then I never looked at budget segment. Can you even save any money to build it yourself at this price range or would a stock store bargain like this E5400 tower for $260 be better?
Is small form factor possible in this price range? Something like this Dell ZinoHD form factor would be really nice and simple.
I do not live near a Microcenter or Fry's. I am in Toronto. I usually shop at DirectCanada.ca
Recommendations appreciated, thanks!
alkemyst
83,769
19
there is an Athlon II 240 system at staples for the same price. not sure if they are in Canada
mbevolution
155
you'll def save money building a system yourself. check newegg.ca and ncix. you should be able to pull together 500w psu (antec trupower new 550w, 40 AR), athlon x4 or better w/ am3 mb ($200), simple case ($30), 500gb hdd ($50), 4gb ddr3 1600 ($105) and dvd-rw (25) for $450. this system will be way faster than the e5400 (which doesn't even meet your target spec).
khon
1,318
124
A copy of windown 7 is going to cost you about $100, and the 4gb of memory will be another $125 or so. As such you certainly won't be able to beat the $260 prebuilt system you linked to (which if any operating system does that include ?)
You can build your own system with all the specs you listed for around $4-500.
KingstonU
1,405
16
Ok looks like at this bottom range of performance that store deals will be better than building it myself. Huh. I think that staples deal that alkemyst recommended is best.
Thanks to all!
BD231
10,568
138
What's wrong with the Turion X2 TL-64? Laptops are extremely cheap to upgrade and the Turions are still a good CPU.
nyker96
5,630
at this price range you'd better wait for a sale from HP/Dell, at 500 or below range, one of those pre builts tends to be cheaper onsale.
ElFenix
102,408
8,596
i wouldn't go for a K8 processor for a new computer these days. if the price were right K10 might be viable, but K10.5 CPUs are so cheap even that is doubtful.
