Hi all, I am having a hard time figuring out this BSOD. I have the log file attached below and just cant fix it. Can anyone help me? I have 4 or 5 different machines that this is happening on. This happens when we go to Bing.com and go to the maps using satelite view. Thanks in advance for your help.
Opened log file 'cdebuglogdebbie4.txt'
0: kd> .sympath srv*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols
Expanded Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols
0: kd> .reload;!analyze -v;r;kv;lmnt;.logclose;q
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
THREAD_STUCK_IN_DEVICE_DRIVER_M (100000ea)
The device driver is spinning in an infinite loop, most likely waiting for
hardware to become idle. This usually indicates problem with the hardware
itself or with the device driver programming the hardware incorrectly.
If the kernel debugger is connected and running when watchdog detects a
timeout condition then DbgBreakPoint() will be called instead of KeBugCheckEx()
and detailed message including bugcheck arguments will be printed to the
debugger. This way we can identify an offending thread, set breakpoints in it,
and hit go to return to the spinning code to debug it further. Because
KeBugCheckEx() is not called the .bugcheck directive will not return bugcheck
information in this case. The arguments are already printed out to the kernel
debugger. You can also retrieve them from a global variable via
"dd watchdog!g_WdBugCheckData l5" (use dq on NT64).
On MP machines it is possible to hit a timeout when the spinning thread is
interrupted by hardware interrupt and ISR or DPC routine is running at the time
of the bugcheck (this is because the timeout's work item can be delivered and
handled on the second CPU and the same time). If this is the case you will have
to look deeper at the offending thread's stack (e.g. using dds) to determine
spinning code which caused the timeout to occur.
Arguments:
Arg1: 88c0e3d8, Pointer to a stuck thread object. Do .thread then kb on it to find
the hung location.
Arg2: 89b8a2e8, Pointer to a DEFERRED_WATCHDOG object.
Arg3: ba4ffcbc, Pointer to offending driver name.
Arg4: 00000001, Number of times "intercepted" bugcheck 0xEA was hit (see notes).
Debugging Details:
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xEA
LAST_CONTROL_TRANSFER: from bf865492 to bf8f95bb
STACK_TEXT:
a4f8f3d4 bf865492 0658820c ebc05010 e35606d8 win32k!vStrWrite32+0x289
a4f8f610 bf8a9116 a4f8f86c 00000000 00000098 win32k!EngStretchBlt+0xb56
a4f8f6b0 bf8a8f07 e35606e8 e3aeb730 00000000 win32k!EngStretchBltROP+0x3a9
a4f8f78c bf8440d3 00000000 00000000 bf8a9088 win32k!BLTRECORD::bStretch+0x41b
a4f8f8c0 bf838590 f20111b6 ffa7064c ffb3c748 win32k!GreStretchBltInternal+0x632
a4f8f8fc 8054088c f20111b6 ffa7064c ffb3c748 win32k!GreStretchBlt+0x30
a4f8f8fc 7c90eb94 f20111b6 ffa7064c ffb3c748 nt!KiFastCallEntry+0xfc
WARNING: Frame IP not in any known module. Following frames may be wrong.
00137ee4 00000000 00000000 00000000 00000000 0x7c90eb94
STACK_COMMAND: kb
FOLLOWUP_IP:
win32k!vStrWrite32+289
bf8f95bb 83450804 add dword ptr [ebp+8],4
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: win32k!vStrWrite32+289
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: win32k
IMAGE_NAME: win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a8548d9
FAILURE_BUCKET_ID: 0xEA_win32k!vStrWrite32+289
Followup: MachineOwner
eax=0027064c ebx=0014edf1 ecx=e9c05008 edx=00000002 esi=0604ca48 edi=00000154
eip=bf8f95bb esp=a4f8f3a4 ebp=a4f8f3d4 iopl=0 nv up ei pl nz ac po nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000212
win32k!vStrWrite32+0x289:
bf8f95bb 83450804 add dword ptr [ebp+8],4 ss:0010:a4f8f3dc=0658820c
ChildEBP RetAddr Args to Child
a4f8f3d4 bf865492 0658820c ebc05010 e35606d8 win32k!vStrWrite32+0x289 (FPO: [4,9,0])
a4f8f610 bf8a9116 a4f8f86c 00000000 00000098 win32k!EngStretchBlt+0xb56 (FPO: [11,134,4])
a4f8f6b0 bf8a8f07 e35606e8 e3aeb730 00000000 win32k!EngStretchBltROP+0x3a9 (FPO: [13,24,4])
a4f8f78c bf8440d3 00000000 00000000 bf8a9088 win32k!BLTRECORD::bStretch+0x41b (FPO: [4,37,4])
a4f8f8c0 bf838590 f20111b6 ffa7064c ffb3c748 win32k!GreStretchBltInternal+0x632 (FPO: [13,68,4])
a4f8f8fc 8054088c f20111b6 ffa7064c ffb3c748 win32k!GreStretchBlt+0x30 (FPO: [12,0,0])
a4f8f8fc 7c90eb94 f20111b6 ffa7064c ffb3c748 nt!KiFastCallEntry+0xfc (FPO: [0,0] TrapFrame @ a4f8f934)
start end module name
804d7000 806e2000 nt ntkrpamp.exe Tue Aug 04 06:13:21 2009 (4A7833F1)
806e2000 80702d00 hal halmacpi.dll Tue Aug 03 22:59:09 2004 (41107B2D)
a4e36000 a4e5ff00 kmixer kmixer.sys Tue Aug 03 23:07:46 2004 (41107D32)
a85b3000 a85c7400 wdmaud wdmaud.sys Tue Aug 03 23:15:03 2004 (41107EE7)
a86e8000 a86ec000 prepdrv prepdrv.sys unavailable (00000000)
a8760000 a876ed80 sysaudio sysaudio.sys Tue Aug 03 23:15:54 2004 (41107F1A)
a8a00000 a8a104e0 mfeavfk mfeavfk.sys Wed Dec 03 09:18:14 2008 (4936BF56)
a8a11000 a8a3ac80 mfehidk mfehidk.sys Wed Dec 03 09:15:28 2008 (4936BEB0)
a8a3b000 a8a5d080 RDPWD RDPWD.SYS Thu Jun 09 16:52:39 2005 (42A8D647)
a8b5e000 a8b6c3a0 mfeapfk mfeapfk.sys Wed Dec 03 09:17:00 2008 (4936BF0C)
a8f0e000 a8f5f580 srv srv.sys Thu Dec 11 03:57:18 2008 (4941001E)
a8fb0000 a8fdbd80 mrxdav mrxdav.sys Tue Dec 18 01:51:33 2007 (47679825)
a91e4000 a91fc7e0 tfsnudfa tfsnudfa.sys Wed Oct 22 12:41:58 2003 (3F96DD86)
a91fd000 a9214f40 tfsnudf tfsnudf.sys Wed Oct 22 12:41:16 2003 (3F96DD5C)
a9215000 a9229640 tfsnifs tfsnifs.sys Wed Oct 22 12:41:09 2003 (3F96DD55)
a9242000 a9245280 ndisuio ndisuio.sys Tue Aug 03 23:03:10 2004 (41107C1E)
a9296000 a9299760 tfsnopio tfsnopio.sys Wed Oct 22 12:41:37 2003 (3F96DD71)
a934a000 a934f500 TDTCP TDTCP.SYS Tue Aug 03 22:58:52 2004 (41107B1C)
a9372000 a9378420 tfsnboio tfsnboio.sys Wed Oct 22 12:41:18 2003 (3F96DD5E)
a93ba000 a93d1480 dump_atapi dump_atapi.sys Tue Aug 03 22:59:41 2004 (41107B4D)
a9422000 a942a7e0 tfsncofs tfsncofs.sys Wed Oct 22 12:41:30 2003 (3F96DD6A)
a9432000 a943b540 drvnddm drvnddm.sys Fri Jun 20 16:55:12 2003 (3EF39EE0)
a9472000 a94e0c00 mrxsmb mrxsmb.sys Fri Oct 24 04:10:39 2008 (4901AD2F)
a94e1000 a950ba00 rdbss rdbss.sys Fri May 05 02:47:55 2006 (445B1F4B)
a950c000 a952dc80 afd afd.sys Thu Aug 14 02:51:42 2008 (48A4002E)
a952e000 a9555c00 netbt netbt.sys Tue Aug 03 23:14:36 2004 (41107ECC)
a957e000 a95d5f80 tcpip tcpip.sys Fri Jun 20 03:45:10 2008 (485B8A36)
a95d6000 a95e8400 ipsec ipsec.sys Tue Aug 03 23:14:27 2004 (41107EC3)
a9609000 a962a700 portcls portcls.sys Tue Mar 16 11:58:17 2004 (40574E49)
a962b000 a965b000 ADIHdAud ADIHdAud.sys Thu May 18 08:43:15 2006 (446C9613)
a967b000 a967d900 Dxapi Dxapi.sys Fri Aug 17 13:53:19 2001 (3B7D843F)
b97e3000 b9816200 update update.sys Tue Aug 03 22:58:32 2004 (41107B08)
b992f000 b995f100 rdpdr rdpdr.sys Tue Aug 03 23:01:10 2004 (41107BA6)
b9960000 b9970e00 psched psched.sys Tue Aug 03 23:04:16 2004 (41107C60)
b9971000 b9987680 ndiswan ndiswan.sys Tue Aug 03 23:14:30 2004 (41107EC6)
b9988000 b99aa680 ks ks.sys Tue Aug 03 23:15:20 2004 (41107EF8)
b99ab000 b99be900 parport parport.sys Tue Aug 03 22:59:04 2004 (41107B28)
b99bf000 b99e4000 HDAudBus HDAudBus.sys Fri Jan 07 17:07:15 2005 (41DF3243)
b99e4000 b9a06e80 USBPORT USBPORT.SYS Tue Aug 03 23:08:34 2004 (41107D62)
b9a07000 b9a40000 e1e5132 e1e5132.sys unavailable (00000000)
b9a40000 b9b4b800 igxpmp32 igxpmp32.sys Fri Jun 23 14:02:00 2006 (449C56C8)
b9b4c000 b9b5f780 VIDEOPRT VIDEOPRT.SYS Tue Aug 03 23:07:04 2004 (41107D08)
b9ba9000 b9bb7b80 drmk drmk.sys Tue Aug 03 23:07:54 2004 (41107D3A)
b9bb9000 b9bc7100 usbhub usbhub.sys Tue Aug 03 23:08:40 2004 (41107D68)
b9bd9000 b9be2480 NDProxy NDProxy.SYS Fri Aug 17 13:55:30 2001 (3B7D84C2)
b9bf9000 b9c02f00 termdd termdd.sys Tue Aug 03 22:58:52 2004 (41107B1C)
b9c09000 b9c11900 msgpc msgpc.sys Tue Aug 03 23:04:11 2004 (41107C5B)
b9c19000 b9c24d00 raspptp raspptp.sys Tue Aug 03 23:14:26 2004 (41107EC2)
b9c29000 b9c33200 raspppoe raspppoe.sys Tue Aug 03 23:05:06 2004 (41107C92)
b9c59000 b9c5cc80 mssmbios mssmbios.sys Tue Aug 03 23:07:47 2004 (41107D33)
b9c81000 b9c9b580 Mup Mup.sys Tue Aug 03 23:15:20 2004 (41107EF8)
b9c9c000 b9cc8a80 NDIS NDIS.sys Tue Aug 03 23:14:27 2004 (41107EC3)
b9cc9000 b9d55480 Ntfs Ntfs.sys Tue Aug 03 23:15:06 2004 (41107EEA)
b9d56000 b9d6c780 KSecDD KSecDD.sys Tue Aug 03 22:59:45 2004 (41107B51)
b9d6d000 b9d81560 drvmcdb drvmcdb.sys Wed Nov 05 20:06:51 2003 (3FA9C8DB)
b9d82000 b9d93f00 sr sr.sys Tue Aug 03 23:06:22 2004 (41107CDE)
b9d94000 b9db3780 fltMgr fltMgr.sys Mon Aug 21 02:14:57 2006 (44E97991)
b9db4000 b9ddfd80 dac2w2k dac2w2k.sys Fri Aug 17 13:52:13 2001 (3B7D83FD)
b9e04000 b9e1ce00 adpu160m adpu160m.sys Wed May 30 02:18:22 2001 (3B14BADE)
b9e1d000 b9e34480 atapi atapi.sys Tue Aug 03 22:59:41 2004 (41107B4D)
b9e35000 b9f0a880 iaStor iaStor.sys Thu Sep 07 20:53:21 2006 (4500E931)
b9f0b000 b9f22800 SCSIPORT SCSIPORT.SYS Tue Aug 03 22:59:39 2004 (41107B4B)
b9f23000 b9f48700 dmio dmio.sys Tue Aug 03 23:07:13 2004 (41107D11)
b9f49000 b9f67880 ftdisk ftdisk.sys Fri Aug 17 13:52:41 2001 (3B7D8419)
b9f68000 b9f78a80 pci pci.sys Tue Aug 03 23:07:45 2004 (41107D31)
b9f79000 b9fa6d80 ACPI ACPI.sys Tue Aug 03 23:07:35 2004 (41107D27)
ba0a8000 ba0b0c00 isapnp isapnp.sys Fri Aug 17 13:58:01 2001 (3B7D8559)
ba0b8000 ba0c2500 MountMgr MountMgr.sys Tue Aug 03 22:58:29 2004 (41107B05)
ba0c8000 ba0d4c80 VolSnap VolSnap.sys Tue Aug 03 23:00:14 2004 (41107B6E)
ba0d8000 ba0e5e80 aic78xx aic78xx.sys Thu May 10 13:23:40 2001 (3AFAF8CC)
ba0e8000 ba0f0180 ql10wnt ql10wnt.sys Fri Aug 17 13:52:14 2001 (3B7D83FE)
ba0f8000 ba101e00 ql1240 ql1240.sys Fri Aug 17 13:52:14 2001 (3B7D83FE)
ba108000 ba115780 aic78u2 aic78u2.sys Thu May 10 13:23:41 2001 (3AFAF8CD)
ba118000 ba120f80 ultra ultra.sys Fri Aug 17 13:52:19 2001 (3B7D8403)
ba128000 ba131d80 ql1080 ql1080.sys Fri Aug 17 13:52:18 2001 (3B7D8402)
ba138000 ba143f80 ql1280 ql1280.sys Fri Aug 17 13:52:16 2001 (3B7D8400)
ba148000 ba153100 ql12160 ql12160.sys Fri Aug 17 13:52:18 2001 (3B7D8402)
ba168000 ba170e00 disk disk.sys Tue Aug 03 22:59:53 2004 (41107B59)
ba178000 ba184200 CLASSPNP CLASSPNP.SYS Tue Aug 03 23:14:26 2004 (41107EC2)
ba188000 ba192080 sisagp sisagp.sys Tue Aug 03 23:07:42 2004 (41107D2E)
ba198000 ba1a2500 viaagp viaagp.sys Tue Aug 03 23:07:42 2004 (41107D2E)
ba1a8000 ba1b2700 alim1541 alim1541.sys Tue Aug 03 23:07:40 2004 (41107D2C)
ba1b8000 ba1c2800 amdagp amdagp.sys Tue Aug 03 23:07:42 2004 (41107D2E)
ba1c8000 ba1d2580 agp440 agp440.sys Tue Aug 03 23:07:40 2004 (41107D2C)
ba1d8000 ba1e2f80 agpCPQ agpCPQ.sys Tue Aug 03 23:07:42 2004 (41107D2E)
ba208000 ba213180 mfetdik mfetdik.sys Wed Dec 03 09:16:45 2008 (4936BEFD)
ba218000 ba220700 wanarp wanarp.sys Tue Aug 03 23:04:57 2004 (41107C89)
ba228000 ba230700 netbios netbios.sys Tue Aug 03 23:03:19 2004 (41107C27)
ba238000 ba240880 Fips Fips.SYS Fri Aug 17 18:31:49 2001 (3B7DC585)
ba248000 ba250d80 HIDCLASS HIDCLASS.SYS Tue Aug 03 23:08:18 2004 (41107D52)
ba288000 ba297900 Cdfs Cdfs.SYS Tue Aug 03 23:14:09 2004 (41107EB1)
ba2b8000 ba2c0d00 intelppm intelppm.sys Tue Aug 03 22:59:19 2004 (41107B37)
ba2c8000 ba2d3000 HECI HECI.sys unavailable (00000000)
ba2d8000 ba2e7d80 serial serial.sys Tue Aug 03 23:15:51 2004 (41107F17)
ba2e8000 ba2f2380 imapi imapi.sys Tue Aug 03 23:00:12 2004 (41107B6C)
ba2f8000 ba304180 cdrom cdrom.sys Tue Aug 03 22:59:52 2004 (41107B58)
ba308000 ba316080 redbook redbook.sys Tue Aug 03 22:59:34 2004 (41107B46)
ba318000 ba324880 rasl2tp rasl2tp.sys Tue Aug 03 23:14:21 2004 (41107EBD)
ba328000 ba32e200 PCIIDEX PCIIDEX.SYS Tue Aug 03 22:59:40 2004 (41107B4C)
ba330000 ba334900 PartMgr PartMgr.sys Fri Aug 17 18:32:23 2001 (3B7DC5A7)
ba338000 ba33ca80 sparrow sparrow.sys Fri Dec 08 09:40:58 2000 (3A311D2A)
ba340000 ba346780 asc asc.sys Fri Aug 17 13:51:58 2001 (3B7D83EE)
ba348000 ba34c380 mraid35x mraid35x.sys Fri Aug 17 13:52:11 2001 (3B7D83FB)
ba350000 ba354880 i2omp i2omp.sys Tue Aug 03 23:00:49 2004 (41107B91)
ba358000 ba35ff80 symc8xx symc8xx.sys Fri Dec 08 09:40:59 2000 (3A311D2B)
ba360000 ba366ee0 sym_hi sym_hi.sys Mon Mar 19 22:51:22 2001 (3AB6EFDA)
ba368000 ba36f7e0 sym_u3 sym_u3.sys Mon Mar 19 22:36:17 2001 (3AB6EC51)
ba370000 ba375c00 ABP480N5 ABP480N5.SYS Fri Aug 17 13:51:59 2001 (3B7D83EF)
ba378000 ba37d780 asc3350p asc3350p.sys Fri Aug 17 13:52:01 2001 (3B7D83F1)
ba380000 ba384ee0 dpti2o dpti2o.sys Tue Mar 20 12:07:16 2001 (3AB7AA64)
ba388000 ba38eaa0 perc2 perc2.sys Mon Apr 23 03:51:37 2001 (3AE40939)
ba390000 ba396560 hpn hpn.sys Mon Apr 23 03:51:37 2001 (3AE40939)
ba398000 ba39cde0 PxHelp20 PxHelp20.sys Mon Aug 02 14:08:25 2004 (410EAD49)
ba3a8000 ba3ac080 raspti raspti.sys Fri Aug 17 13:55:32 2001 (3B7D84C4)
ba3e8000 ba3ee000 kbdclass kbdclass.sys Tue Aug 03 22:58:32 2004 (41107B08)
ba3f0000 ba3f5a00 mouclass mouclass.sys Tue Aug 03 22:58:32 2004 (41107B08)
ba408000 ba40da80 ssrtln ssrtln.sys Mon Jul 14 11:28:21 2003 (3F12F645)
ba410000 ba416180 HIDPARSE HIDPARSE.SYS Tue Aug 03 23:08:15 2004 (41107D4F)
ba418000 ba41d200 vga vga.sys Tue Aug 03 23:07:06 2004 (41107D0A)
ba420000 ba424a80 Msfs Msfs.SYS Tue Aug 03 23:00:37 2004 (41107B85)
ba428000 ba42f880 Npfs Npfs.SYS Tue Aug 03 23:00:38 2004 (41107B86)
ba430000 ba437000 Nwsvc65_ Nwsvc65_.sys unavailable (00000000)
ba438000 ba43e220 mferkdk mferkdk.sys Wed Dec 03 09:19:28 2008 (4936BFA0)
ba460000 ba464500 watchdog watchdog.sys Tue Aug 03 23:07:32 2004 (41107D24)
ba470000 ba476c20 mfebopk mfebopk.sys Wed Dec 03 09:18:58 2008 (4936BF82)
ba488000 ba48d000 usbuhci usbuhci.sys Tue Aug 03 23:08:34 2004 (41107D62)
ba490000 ba496800 usbehci usbehci.sys Tue Aug 03 23:08:34 2004 (41107D62)
ba498000 ba49f000 fdc fdc.sys unavailable (00000000)
ba4a0000 ba4a8000 atmeltpm atmeltpm.sys Tue May 17 07:20:06 2005 (4289FD96)
ba4a8000 ba4ac880 TDI TDI.SYS Tue Aug 03 23:07:47 2004 (41107D33)
ba4b0000 ba4b4580 ptilink ptilink.sys Fri Aug 17 13:49:53 2001 (3B7D8371)
ba4b8000 ba4bb000 BOOTVID BOOTVID.dll Fri Aug 17 13:49:09 2001 (3B7D8345)
ba4bc000 ba4bfa80 cpqarray cpqarray.sys Fri Aug 17 13:52:05 2001 (3B7D83F5)
ba4c0000 ba4c3200 aha154x aha154x.sys Fri Aug 17 13:51:59 2001 (3B7D83EF)
ba4c4000 ba4c7f80 symc810 symc810.sys Fri Dec 08 09:40:59 2000 (3A311D2B)
ba4c8000 ba4cb980 dac960nt dac960nt.sys Fri Aug 17 13:52:13 2001 (3B7D83FD)
ba4cc000 ba4cef00 amsint amsint.sys Fri Aug 17 13:52:01 2001 (3B7D83F1)
ba4d0000 ba4d3a00 asc3550 asc3550.sys Fri Aug 17 13:51:56 2001 (3B7D83EC)
ba4d4000 ba4d7e80 ini910u ini910u.sys Fri Aug 17 13:52:07 2001 (3B7D83F7)
ba4d8000 ba4db680 cbidf2k cbidf2k.sys Fri Aug 17 13:52:06 2001 (3B7D83F6)
ba56c000 ba56e280 rasacd rasacd.sys Fri Aug 17 13:55:39 2001 (3B7D84CB)
ba57c000 ba57e580 hidusb hidusb.sys Fri Aug 17 14:02:16 2001 (3B7D8658)
ba580000 ba583a00 kbdhid kbdhid.sys Tue Aug 03 22:58:33 2004 (41107B09)
ba584000 ba586f80 mouhid mouhid.sys Fri Aug 17 13:47:57 2001 (3B7D82FD)
ba588000 ba58bc80 serenum serenum.sys Tue Aug 03 22:59:06 2004 (41107B2A)
ba590000 ba592580 ndistapi ndistapi.sys Fri Aug 17 13:55:29 2001 (3B7D84C1)
ba5a8000 ba5a9b80 kdcom kdcom.dll Fri Aug 17 13:49:10 2001 (3B7D8346)
ba5aa000 ba5ab100 WMILIB WMILIB.SYS Fri Aug 17 14:07:23 2001 (3B7D878B)
ba5ac000 ba5ad480 aliide aliide.sys Fri Aug 17 13:51:54 2001 (3B7D83EA)
ba5ae000 ba5afa00 cmdide cmdide.sys Fri Aug 17 13:51:51 2001 (3B7D83E7)
ba5b0000 ba5b1380 toside toside.sys Fri Aug 17 13:51:52 2001 (3B7D83E8)
ba5b2000 ba5b3500 viaide viaide.sys Tue Aug 03 22:59:42 2004 (41107B4E)
ba5b4000 ba5b5580 intelide intelide.sys Tue Aug 03 22:59:40 2004 (41107B4C)
ba5b6000 ba5b7700 dmload dmload.sys Fri Aug 17 13:58:15 2001 (3B7D8567)
ba5b8000 ba5b9e00 cd20xrnt cd20xrnt.sys Fri Aug 17 13:52:04 2001 (3B7D83F4)
ba5ba000 ba5bb580 perc2hib perc2hib.sys Mon Apr 23 03:51:37 2001 (3AE40939)
ba5ca000 ba5cb5c0 sscdbhk5 sscdbhk5.sys Mon Jul 14 11:28:38 2003 (3F12F656)
ba5cc000 ba5cd100 swenum swenum.sys Tue Aug 03 22:58:41 2004 (41107B11)
ba5ce000 ba5cf280 USBD USBD.SYS Fri Aug 17 14:02:58 2001 (3B7D8682)
ba5d2000 ba5d4000 i2omgmt i2omgmt.SYS Tue Aug 03 23:00:50 2004 (41107B92)
ba5d4000 ba5d5f00 Fs_Rec Fs_Rec.SYS Fri Aug 17 13:49:37 2001 (3B7D8361)
ba5d6000 ba5d7080 Beep Beep.SYS Fri Aug 17 13:47:33 2001 (3B7D82E5)
ba5d8000 ba5d9080 mnmdd mnmdd.SYS Fri Aug 17 13:57:28 2001 (3B7D8538)
ba5da000 ba5db080 RDPCDD RDPCDD.sys Fri Aug 17 13:46:56 2001 (3B7D82C0)
ba5ee000 ba5ef100 dump_WMILIB dump_WMILIB.SYS Fri Aug 17 14:07:23 2001 (3B7D878B)
ba616000 ba6178a0 tfsnpool tfsnpool.sys Wed Oct 22 12:41:10 2003 (3F96DD56)
ba670000 ba670d00 pciide pciide.sys Fri Aug 17 13:51:49 2001 (3B7D83E5)
ba722000 ba722b80 Null Null.SYS Fri Aug 17 13:47:39 2001 (3B7D82EB)
ba78f000 ba790000 smsmdm smsmdm.sys unavailable (00000000)
ba7a0000 ba7a0c00 audstub audstub.sys Fri Aug 17 13:59:40 2001 (3B7D85BC)
ba7de000 ba7ded00 dxgthk dxgthk.sys Fri Aug 17 13:53:12 2001 (3B7D8438)
ba7fb000 ba7fb880 tfsndres tfsndres.sys Wed Oct 22 12:42:04 2003 (3F96DD8C)
ba7fc000 ba7fcfe0 tfsndrct tfsndrct.sys Wed Oct 22 12:41:35 2003 (3F96DD6F)
bf000000 bf011580 dxg dxg.sys Tue Aug 03 23:00:51 2004 (41107B93)
bf012000 bf022000 igxprd32 igxprd32.dll Fri Jun 23 14:01:31 2006 (449C56AB)
bf022000 bf049000 igxpgd32 igxpgd32.dll Fri Jun 23 14:01:20 2006 (449C56A0)
bf049000 bf185080 igxpdv32 igxpdv32.DLL Fri Jun 23 14:00:50 2006 (449C5682)
bf186000 bf385000 igxpdx32 igxpdx32.DLL Fri Jun 23 14:02:40 2006 (449C56F0)
bf800000 bf9c5f00 win32k win32k.sys Fri Aug 14 04:22:01 2009 (4A8548D9)
bffa0000 bffe5c00 ATMFD ATMFD.DLL Wed Aug 04 00:56:56 2004 (411096C8)
Unloaded modules:
a4e36000 a4e60000 kmixer.sys
Timestamp: unavailable (00000000)
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
a50b8000 a50e2000 kmixer.sys
Checksum: 00000000
a533a000 a5364000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
a54a4000 a54ce000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
a5686000 a56b0000 kmixer.sys
Checksum: 00000000
a5864000 a588e000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
a592e000 a5958000 kmixer.sys
Checksum: 00000000
a5b10000 a5b3a000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
a5c1a000 a5c44000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
a5d84000 a5dae000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
a5dd6000 a5e00000 kmixer.sys
Checksum: 00000000
a5ea0000 a5eca000 kmixer.sys
Checksum: 00000000
a5f92000 a5fbc000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
a6084000 a60ae000 kmixer.sys
Checksum: 00000000
a614e000 a6178000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
a63f8000 a6422000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
a6602000 a662c000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
a694c000 a6976000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
a718d000 a71b7000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
a7257000 a7281000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
a74d9000 a7503000 kmixer.sys
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
a752b000 a7555000 kmixer.sys
Checksum: 00000000
Closing open log file cdebuglogdebbie4.txt
Arguments:
the hung location.
Debugging Details:
BUGCHECK_STR: 0xEA
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: win32k
Unloaded modules:
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
