I just set up dual monitors, using one GForce 9500GT video card, and the second monitor is slightly fuzzy. How do I fix this?
If I unplug the Gateway from the video card, the Dell looks crisp. The Dell only looks blurry when I have both monitors plugged into the video card.
The video card is updated with the latest driver and both monitors are set at the native resolution and highest refresh rate. I've also enabled the truetype text option.
Using Win7 64bit.
Monitor 1 is a 24' Gateway plugged in via DVI.
Monitor 2 is a 17' Dell plugged in via VGA.
Using Win7 64bit.
