Help With Bluej
Shahr
Hi! my name is Shahr and im using bluej, For Some Reason My Code Isnt Working Properly
import java.util.Scanner;
public class Katan
public static void main(String[]args)
Scanner in=new Scanner(System.in);
int n,i,math=1;
System.out.println("Enter N");
n=in.nextInt();
for(i=0;i<=1;i++)
if(n<10)
math=math*n;
n=in.nextInt();
else
n=in.nextInt();
System.out.println(math);
Here Is My Code And Its Supposedly Needs To Print Out Enter N Once And For Some Reason It Prints It 3 Times And Gives The User 3 Time To Enter The Number Again
import java.util.Random;
public class SheshBesh
Random in=new Random();
int Cube1,Cube2,Benim;
Cube1=in.nextInt(6)+1;
Cube2=in.nextInt(6)+1;
while(Cube1!= 5&&Cube2!=6)
if(Cube1==6&&Cube2==5)
Benim=Cube2;
Cube2=Cube1;
Cube1=Benim;
else
System.out.println("Cube1= " + Cube1);
System.out.println("Cube2= " + Cube2);
System.out.println("שש בש");
This Is Another Example Of It Not Working Well. This Code Is Simulating A Cube And Pasting Its Results Until The Cubes Are Either 6 5 Or 5 6, And For Some Reason It Doesnt Count The && And When One Of The Cubes Equals 6 or 5 It Is Ending The Loop, Is It Me? Or Bluej :p
Ken g6
Moderator
Dec 11, 1999
16,836
4,817
75
First, use code tags!
Java:
public class Katan
        int n,i,math=1;
        n=in.nextInt();
        for(i=0;i<=1;i++)
            if(n<10)
                math=math*n;
                n=in.nextInt();
            else
                n=in.nextInt();
I'm pretty sure your bug is in the first section there. in.nextInt() asks for a value every time it's called. Can you step through the code and see how it's called three times? If not, BlueJ should have a debugger that can step through the code for you from the point where you set a breakpoint.
Another option might be
to change your System.out.println values so each one is unique so you know where calls are being made from.
But that might be giving away too much. ;)
